Successfully Overhauled my 46RE #1590299
03/09/14 12:46 PM
03/09/14 12:46 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Feeling pretty good on my first overdrive overhaul on my daughters 2001 Ram 4x4. Lost 1st gear 3 weeks ago. When I got the overdrive unit apart I found crispy critter steels and clutches. I went ahead and replaced the torque converter and replaced the plastic accumulator piston with the aluminum one with two extra seals. It was a chore, but I took my time on disassembly and reassembly. Also replaced the transducer and solenoid in the valve body that set off the check engine light and also caused the hard start condition.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Successfully Overhauled my 46RE [Re: ChrgrCuda] #1590300
03/09/14 01:53 PM
03/09/14 01:53 PM
Kansas wishing I was in Ohio
SeanD Offline
SeanD  Offline
ChrgrCuda, you've got mail.
Re: Successfully Overhauled my 46RE [Re: SeanD] #1590301
03/09/14 02:22 PM
03/09/14 02:22 PM
Texas, USA
Texas, USA
Replied
Re: Successfully Overhauled my 46RE [Re: ChrgrCuda] #1590302
03/09/14 02:52 PM
03/09/14 02:52 PM
SeanD Offline
SeanD  Offline
Back at 'cha.
Thank you!
Re: Successfully Overhauled my 46RE [Re: ChrgrCuda] #1590303
03/10/14 08:57 PM
03/10/14 08:57 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Cool! Where did you get the kit? Not cheap even doing it yourself.
Re: Successfully Overhauled my 46RE [Re: ChrgrCuda] #1590304
03/10/14 09:08 PM
03/10/14 09:08 PM
Garry Owen Offline
Garry Owen  Offline
Want to do my 48re?
Re: Successfully Overhauled my 46RE [Re: Garry Owen] #1590305
03/10/14 10:15 PM
03/10/14 10:15 PM
Texas, USA
Texas, USA
Maybe. If you pull it out, and buy all the parts and reinstall it.
Re: Successfully Overhauled my 46RE [Re: redraptor] #1590306
03/10/14 10:17 PM
03/10/14 10:17 PM
Texas, USA
Texas, USA
Bought the kit, sensors, transducers and converter from Cope a racing transmissions.
Re: Successfully Overhauled my 46RE [Re: ChrgrCuda] #1590307
03/30/14 01:34 AM
03/30/14 01:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
