How to restore my alternator at home?? #1590146
03/08/14 09:42 PM
03/08/14 09:42 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Friends, I have some questions about restoring my alternator at home.
1) How to remove the pulley, it is pressed? The use of a pulley puller is correct? No need to use heat on the pulley?
2) How do I even leave the housing of the alternator with "as new" appearance without sandblasting (because aluminum is wearing and matte) and cleaning products that do not think outside of the U.S..
Is there any method which let homemade aluminum as new and do not leave it dark?
3) Are the pulley and screws zinc plated?
Thank's in advance.
Re: How to restore my alternator at home?? [Re: v8punch] #1590147
03/08/14 09:43 PM
03/08/14 09:43 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
one more picture
Re: How to restore my alternator at home?? [Re: v8punch] #1590148
03/08/14 09:47 PM
03/08/14 09:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are some visual cues
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590149
03/08/14 09:48 PM
03/08/14 09:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590150
03/08/14 09:49 PM
03/08/14 09:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590151
03/08/14 09:50 PM
03/08/14 09:50 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590152
03/08/14 09:51 PM
03/08/14 09:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590153
03/08/14 09:55 PM
03/08/14 09:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There is a puller designed especially for removing the pulley, you should not need heat.
You can try blasting with soda or corn starch, it is easier on aluminum than other materials.
Thank's in advance.
No, they are painted black, the grooves of the pulley were the belt rides was typically left bare steel.
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590154
03/08/14 10:17 PM
03/08/14 10:17 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Thank's ScottSmith_Harms, I'll try soda blast this week and post the pictures.
Don't you have a link to this pulley puller?
Re: How to restore my alternator at home?? [Re: v8punch] #1590155
03/09/14 12:03 AM
03/09/14 12:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Shop around, prices and quality vary.
Ebay
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590156
03/09/14 12:50 AM
03/09/14 12:50 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Measure the pulley's location on the shaft. This will help get it back in proper position so the belts will line up when installed. To reinstall the pulley, I put the pulley directly on a 100 watt light bulb. In about five minuets it will be so hot you will need an oven mitt to pick it up and slide it back on the shaft. The pulley will cool off and be firmly on the shaft. The light bulb will not over heat the pulley like outer means of heat(I.E. open flame)can. Also There are different pulley hole sizes for different alternator shaft sizes.
Re: How to restore my alternator at home?? [Re: convx4] #1590157
03/09/14 07:18 AM
03/09/14 07:18 AM
Indiana
RagtopChallenger Offline
Indiana
What a creative idea on heating up a pulley!
Too bad our Government outlawed the light bulb.......
Re: How to restore my alternator at home?? [Re: RagtopChallenger] #1590158
03/09/14 01:17 PM
03/09/14 01:17 PM
Tropicalcats Offline
That's because they don't want us to see what their doing to us.
Re: How to restore my alternator at home?? [Re: Tropicalcats] #1590159
03/09/14 08:15 PM
03/09/14 08:15 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Whent a friend who tried to withdraw the pulley with a pulley puller without success.
I do not know if the alternator shaft is thinner than the shaft of the drawer, the fact is that the pulley does not move, coming to feather the edge of the pulley (the appropriate part to install the puller).
Now I need to pull apart the pulley, and straighten it's edge.
Re: How to restore my alternator at home?? [Re: v8punch] #1590160
03/10/14 01:37 AM
03/10/14 01:37 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The only puller to use draws on the flange in front of the pulley itself. The one I use has two halves like the one posted. The halves go over the flange and pull on it. The pulley itself is not strong enough to pull on without bending.
Craig
Re: How to restore my alternator at home?? [Re: denfireguy] #1590161
03/10/14 01:50 AM
03/10/14 01:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Craig
Don't use ANYTHING that looks like this, it will ruin/bend your pulley!
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590162
03/10/14 11:33 AM
03/10/14 11:33 AM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
I know this ...... the worst way.
Now I'm afraid that I'll need another double pulley.
Re: How to restore my alternator at home?? [Re: v8punch] #1590163
03/10/14 12:38 PM
03/10/14 12:38 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The correct puller is cheap. I bought one at a local parts store.
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590164
03/11/14 02:38 PM
03/11/14 02:38 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Scott, on item description says:
Compatible With Late Model GM, Ford And Chrysler Engines.
Will this fit old pulley alternators??
Re: How to restore my alternator at home?? [Re: ScottSmith_Harms] #1590165
03/19/14 06:52 PM
03/19/14 06:52 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Friends, I got a proper pulley puller, and after using a lever force of almost 60cm, and a lot of strength in the arm, them after a few snaps of the pulley, it left ....
