restarting body work after ~10 yrs #1589959
03/08/14 05:45 PM
03/08/14 05:45 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
I have a 71 RR that was 95% ready for paint. Due to career change, relocation, no garage, etc, the car sat in a storage unit for 10 yrs while I got a place to restart the hobby.
Now I have the place, and it looks like some rust patina has made it through some of the areas that were primered. No bubbling, just patina. I guess my question is if I have to re blast the whole car and redo the body work or if I can locally address the bad spots. I'll try to take some pics to make this more clear. Primered with Dupont epoxy primer.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589960
03/08/14 05:54 PM
03/08/14 05:54 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
In order to remove the rust that you are seeing you will have to take that area all down to steel in order to remove the rust-either with a D/A or some type of sander or depending on location of the rust you may be able to sand blast it.
Sorry..but that is the only way to do it correctly so it will last.
Re: restarting body work after ~10 yrs [Re: GLR] #1589961
03/08/14 06:30 PM
03/08/14 06:30 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
Thanks. Some pics.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589962
03/08/14 06:31 PM
03/08/14 06:31 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
Re: restarting body work after ~10 yrs [Re: Molloy] #1589963
03/08/14 06:32 PM
03/08/14 06:32 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
Re: restarting body work after ~10 yrs [Re: Molloy] #1589964
03/08/14 06:40 PM
03/08/14 06:40 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I would probably sand blast it again and put it in epoxy.
Re: restarting body work after ~10 yrs [Re: GLR] #1589965
03/08/14 06:47 PM
03/08/14 06:47 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
Here's the primer I used back in 2004. Epoxy. I guess I should have used more coats.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589966
03/08/14 07:00 PM
03/08/14 07:00 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
That epoxy is quite old, I wouldn't use it. It's not worth taking a chance. Buy new Epoxy and Catalyst.
Re: restarting body work after ~10 yrs [Re: GLR] #1589967
03/09/14 12:41 AM
03/09/14 12:41 AM
USA
Molloy Offline OP
Molloy  Offline OP
USA
I know, just showing what I used. Anyone want to recommend a good epoxy primer that will stick to what I have now? In fact, I'm looking for a whole system for primer and a good match for B5. Obviously I'm not a body guy so tips welcome.
Like you suggested, I will need to sand and blast some of it where the rust is, but I'd really like to avoid stripping the whole car because the body work is 99% done.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589968
03/09/14 01:04 AM
03/09/14 01:04 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would re scuff by hand with red scotchbrite pads and then re prime with fresh dupont epoxy primer.
No way I would strip the whole car down again. That's too much blasting and stress on the metal.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589969
03/09/14 01:31 AM
03/09/14 01:31 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
No matter what the prep, are you gonna be comfortable using that as a foundation???
T'was me, I'd start with a clean slate...
Then you'll KNOW what yer working with...
Re: restarting body work after ~10 yrs [Re: Molloy] #1589970
03/09/14 01:37 AM
03/09/14 01:37 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I would blast the whole thing, you never know if its started underneath and hasn't shown through only to come through the paint later. Most primer/sealers can be mixed two different ways, one way a primer filler the other as a sealer. Primer will absorb moisture over time allowing the rust you see. Blast it now it will save money in the long run.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: restarting body work after ~10 yrs [Re: RSNOMO] #1589971
03/09/14 01:40 AM
03/09/14 01:40 AM
USA
Molloy Offline OP
Molloy  Offline OP
USA
I know but I'm busy living in denial.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589972
03/09/14 01:44 AM
03/09/14 01:44 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
It's a '71 Ply...
Make it RIGHTEOUS...
Re: restarting body work after ~10 yrs [Re: RSNOMO] #1589973
03/09/14 10:36 AM
03/09/14 10:36 AM
SE Pa.
LimeliteAero Offline
SE Pa.
theres no way I would move forward unless you have no conscience and plan to sell.
Re: restarting body work after ~10 yrs [Re: RSNOMO] #1589974
03/09/14 10:55 AM
03/09/14 10:55 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, I know it's a lot of work, I have been doing restorations for 34 years. The problem is (as stated above) there is a good chance that there is rust under the epoxy that you can't see because it hasn't came through the epoxy yet but it is still there. It would be best to start over because not only is paint and other materials expensive but you have to factor in your time to redo the car again when the rust starts coming through your paint finish.
I don't know what you have for paint/material supplier but when PPG went to the DPLF series epoxy years ago ... I didn't like it's characteristics and I was talking with a PPG rep and he said that the OMNI epoxy works like the original DP epoxy and I experimented with it and it does work very well. I do not like the OMNI paint at all..it is cheap/poor quality paint.
You can use the cheaper sandable primers that each paint company makes, it usually sands well but it does shrink. So I would use a quality sandable primer and make sure that you read and follow all the paint manufactures instructions.
If you have any other questions, please feel free to ask.
Note; Picture is of a customers car that I am restoring now. 72 Road Runner 451 stroker 4-speed dana.
Re: restarting body work after ~10 yrs [Re: GLR] #1589975
03/09/14 12:50 PM
03/09/14 12:50 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Start from scratch. 2 or 3 good coats of epoxy then get some 2K on it.
Re: restarting body work after ~10 yrs [Re: AdamR] #1589976
03/09/14 01:01 PM
03/09/14 01:01 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
You want to watch the amount of Epoxy that you apply. Follow the paint manufactures recommendations on how many coats of primer to apply. I know that PPG recommends only a maximum of 2 coats of epoxy and watch your recoat times. It also depends on the fluid tip size that is in your spray gun. I use a 1.4 fluid tip for epoxy.
Re: restarting body work after ~10 yrs [Re: Molloy] #1589977
03/09/14 02:57 PM
03/09/14 02:57 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
SPI - Southern Polyurethanes
Awesome stuff, reasonable price, excellent customer service & advice & no I dont work for them. Painted lots of stuff with it and had great success. You can call the owner of the company and get advice on product & process.
the surface rust really doesn't look bad on your
71 so you should be able to get it into epoxy pretty quickly, wire wheel the worst rust & a light DA sand of all else then shoot!
good luck.
