Acetone for Starter Fluid
#1589658
03/07/14 10:06 PM
03/07/14 10:06 PM
Posts: 530 SW CO
HemiSportFury
SW CO
My 528 Hemi is a pain to start if it's cold. It has a Speed Demon on an Indy 426-2 manifold and MSD 6AL ignition. If it's been setting for a while, I have to crank forever to get it to fire, and usually by the time it does fire a couple of plugs will be loaded up and it will run rough for a few minutes. I have an electric fuel pump so the bowls are full when I go to start, and I have a manual choke but I have to pump and pump the pedal to finally get it to fire.
So today I did some checking to make sure I had spark when it was cranking (sure did. Ouch!). The accelerator pump was squirting fuel. No start. So instead of cranking and pumping I poured a little acetone in each of the barrels. Hit the starter and Boom! it fired right up instantly hitting on all cylinders.
I know acetone is one of the things people talk about as a fuel additive but it does little good to put it in the tank because it evaporates so fast. So, I may just have to put some is a squirt gun and go though this routine on cold starts. Better than wearing out the starter. I may try xyol next time since I read of it's use too but the acetone sure worked good this time.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Acetone for Starter Fluid
[Re: HemiSportFury]
#1589663
03/08/14 01:05 AM
03/08/14 01:05 AM
RapidRobert
You should not have to add acetone or anything else to make it act right. Even tho it bit you when you checked it I'd want a good blue spark & I'd jump from the batt or st relay directly to the coil to get the hottest spark possible to see if that's the issue. Might be bad gas. #1 the choke has to be dead on in cold(er) weather for it to start. Mine (& thousands of others) fires right off in subzero weather if I floor it once to set the choke then I start it. Not sure how much your dual quad intake increases the difficulty since I've never owned one (it's a coming tho)
[Re: HemiSportFury]
#1589664
03/09/14 12:12 PM
03/09/14 12:12 PM
Posts: 180 3rd rock
kloyiod
3rd rock
My 528 Hemi is a pain to start if it's cold. If it's been setting for a while, I have to crank forever to get it to fire, and usually by the time it does fire a couple of plugs will be loaded up and it will run rough for a few minutes. I have an electric fuel pump so the bowls are full when I go to start, and I have a manual choke but I have to pump and pump the pedal to finally get it to fire.
This whole statement is oxymoronic, it makes no sense. It should start, let me give you a example. Between my to old cars, 383 & /6 that have mechanical pumps. If I let them sit for a couple weeks, I will either crank the snot out of them to prime the system, or give a shot down the throat and fire immediately. A friends 383 had the same issue till he added a inline electric pump, along with the mechanical pump that he only uses to prime before start. Turns the pump on for a minute or so, you hear the pump load up when it pressurizes, couple of pumps and boom. Maybe you need to wait a minute or so before cranking to pressurize yours? That or there's another problem somewhere? Anything that's flammable will work, I've used lacquer thinner, grain alcohol, lighter fluid, gas, etc. to answer your question. Good Luck
[Re: Rug_Trucker]
#1589668
03/09/14 09:47 PM
03/09/14 09:47 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
WD40 has worked for me in the past.
I have too, for the lawn mower. But I thought I read on this forum that WD40 washed off the oil on cylinder walls or was somehow detrimental to engine internals in some other way?
[Re: HemiSportFury]
#1589669
03/09/14 11:01 PM
03/09/14 11:01 PM
Posts: 530 SW CO
HemiSportFury
SW CO
First, to respond to RR's comment, it has a very hot spark. It jumped at least a half of an inch and was very broad and blue.
The acetone was a test to see if it was a fuel volatility issue, at least in part. I let the electric fuel pump run until there is fuel in the bowls, which I confirmed by observing the squirters. Admittedly the fuel is a little old but it doesn't start great with fresh fuel and my 383 and Rubicon both will sit for while especially this time of year but start fine.
I think it may be a combination of things but the low volatility of modern fuel is the biggest culprit. The Indy 426-2 is a single carb single plain high rise manifold with very large runners. With the carb off you can see the intake valves of the center four cylinders. What I believe is happening is especially with a cold manifold very little of the fuel vaporizes and fuel washes down the runners and fouls the plugs, which hemis are known for. I've tried every combination of choke setting but nothing worked as well as the acetone did. When I lived in the Midwest I used to mix racing fuel in each tank so that probably helped but there is no racing fuel available around here and at 7,000 feet I don't need it anyway. Maybe I'll try some Av gas but I'm sure open to suggestions.
[Re: MoparMarq]
#1589670
03/09/14 11:16 PM
03/09/14 11:16 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I never heard that. I had leaky jet bowls on a TQ and I used WD40 to get things going. It keeps assembled short block cylinders clean.
[Re: Rug_Trucker]
#1589671
03/09/14 11:30 PM
03/09/14 11:30 PM
Posts: 22,728 Bitopia
jcc
Bitopia
I thought the WD-40, etc aerosol starting solutions were more for the very flammable propane propellant used in the spray cans, rather then the actual contents.
And I never bought into the starting ether "washing " oil off the cylinders idea, unless it was used as maybe, just maybe as a liquid, and not a spray.
[Re: Paul_Fancsali]
#1589673
03/10/14 07:23 PM
03/10/14 07:23 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
On my GTX I turn on the pumps, listen for the bowls to fill, pump the gas 5 times (No chokes) and it fires right up even if its been sitting for several weeks.
No excessive cranking and I only have to feather the gas for about 30 seconds to a minute before it will hold idle speed when its really cold out (been 20-30F here the last few weeks)
Had it out last weekend, lots of fun!
Odd you are having an issue getting it to fire, perhaps not enough pump shot?
"I think its got a hemi"
