Re: Have '00 Dodge Ram 2500 V10 auto, needs trans...
[Re: SeanD]
#1589365
03/19/14 06:18 AM
03/19/14 06:18 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
They are easy to rebuild. You can get everything you need from John at Cope Racing Transmissions. You will also need a FSM or O/H manual from ATSG for your transmission for torque specifications. Tools Needed Snap Ring Pliers Slide Hammer 1/4" Drive Torque Wrench for Valve Body 3/8 Drive Torque Wrench for everything else
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: SeanD]
#1589367
03/19/14 08:40 PM
03/19/14 08:40 PM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
Any help on who to contact for rebuild kit or preferably new trans and converter.
Thanks in advance.
Just for giggles, what are the symptoms that lead you to a rebuild. There are some problems that are electronic that can be remedied. Just asking.
[Re: SeanD]
#1589369
03/20/14 04:48 PM
03/20/14 04:48 PM
ChrgrCuda
Texas, USA
Make absolutely sure that you keep everything CLEAN. Valve bodies do not appreciate debris or contamination. You will need the specific tool for the overdrive unit and as mentioned an H-press for the 600lbs spring. A clean parts cleaner is a big plus as well. Also make sure you order both bands front and rear as some kits only come with one. You will also have to order the transducer and solenoid for the valve body separately.
[Re: ChrgrCuda]
#1589370
03/21/14 12:24 AM
03/21/14 12:24 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
most overhauls do not need a new rear band it is only applied in rev or manual low so it gets very little use.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1589375
03/21/14 02:41 PM
03/21/14 02:41 PM
Guitar Jones
Perhaps true, however why not replace it while you have it apart? Seems to me if you don't want a half ass overhaul why not do it right the first time? I guess I'm not big into removing and reinstalling transmissions.
If that's what u want to do that's fine but 99.9% of the time replacing the rear band is a waste of money unless you where having problems with rev slipping. It is not a shifting band it is applied while you are sitting still.
I spent 27 years in the business and have done more of these units than most people have ever seen. And most of the time the rear bands look like new.
There is a big difference in a true rebuilder that knows what is good and what is bad by looking at the parts and someone that is just a parts changer.
Absolutely true. I was a trans tech at a Dodge dealer for over 20 years. I've literally rebuilt thousands of these things and can count on the fingers of one hand the times a rear band needed to be replaced.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: ChrgrCuda]
#1589378
03/21/14 07:14 PM
03/21/14 07:14 PM
Guitar Jones
Perfect example why Chrysler has such a bad reputation regarding service departments. There is a reason why these technicians have rebuilt "thousands" of these transmissions......just replace what is absolutely necessary that will get the customer out of their hair.
Ah, wrong. As I've said before people that don't work in the business have no clue how it's done. When the manufacturer is paying for the repair they dictate the terms and process. You can't just replace parts "because you are in there". Replaced parts are sent back to the manufacturer and analyzed. If they are not bad they are charged back to the dealer and maybe even the entire repair. Even if they don't charge the repair back your warranty costs are compared to every other dealer in the nation. If you are high they send in an audit team. If that happens you better hope every little jot and tittle is documented, time stamped and signed for as returned otherwise you are facing a major charge back.
They will take a sample of say maybe 100 tickets over a weeks time. They average what they are charging back then multiply that by however many months or years the audit was for. The dealer can get hit for hundreds of thousands of dollars over very minor infractions.
Secondly most every dealer tech in this country works flat rate. Meaning if they aren't working they aren't getting paid and sometimes when they are working they are working for nothing. Case in point if I overhauled a trans and didn't replace the rear band and it went bad within a year and/or 12,000 miles guess what? I'm, doing it for free and the dealer is eating the parts because the manufacturer isn't paying that claim.
So if you think I would risk any of those scenarios by not replacing the rear band you have no clue.
[Re: mrrandyj]
#1589384
03/22/14 01:35 AM
03/22/14 01:35 AM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
OK, So I looked at Chrgrcuda's profile, his thoughts about replacing everything make sense, once you see he is an airplane mechanic. Big differences between working on a car, and working on a plane. I suspect there is little opportunity for "warranty" service on an airplane engine.
The automotive industry is held to a standard of being weary of replacing parts unnecessarily. A $40 part might not break the bank, but it might be very wasteful if that $40 part will not cause a problem over the life expectancy of the overhaul service. In the automotive industry, the standard set by law, is to replace only defective parts, and reuse parts that are still serviceable. Law suits have been filed and large settlements paid out by auto repair shops that have replaced parts that were not proven to be faulty.
To that point, there is also a huge difference in the quality of replacement parts between the two industries. Air craft quality standards are much higher then automotive standards. To assume a new replacement automotive part is going to be as good or a better quality part then what may have been in service, is expecting a lot these days. That makes the concept of replacing something "just because you're in there" somewhat questionable in the automotive industry.
This concept leads to a few quick questions for Mr Chrgrcuda. If you inspect the brakes on your car, do you always replace them "while you're in there" even if they are still good? Do you replace your tires every time to rotate them? My point is, sometimes replacing every part is not required if the part shows no sign of wear or age.
If you feel the need to replace everything you touch, go for it, but do not judge everyone else by the industry standard in which you work. I promise most of the world functions on a lot lower standard of nearly everything required of the airline industry. Frankly, I'm OK with that. I don't fly very often, but I like the idea that the last guy that worked on the plane I'm going to ride in, replace everything when he repaired something.
That said, the last time I checked, my car doesn't do well leaving the ground, even momentarily, without support (hoist or jack), without receiving severe trauma. I do not need to hold it to aircraft standards, I don't need to replace every part, nut, or bolt, every time I do a major overhaul. I live in the real automotive world, if the parts are not defective, I'm going to reuse them. Gene
[Re: poorboy]
#1589385
03/22/14 03:54 AM
03/22/14 03:54 AM
ChrgrCuda
Texas, USA
Mr. Poorboy:
Good question and your points are valid regarding the two industries. However, pulling the wheel and inspecting brake shoes (especially rotors) is much less labor intensive when compared to pulling a transmission (especially in a 3/4 ton truck, 4x4, etc). I would not think one would simply pull a transmission out and disassemble for a routine inspection (unless a racecar), hence changing a $40.00 component "while you're in there."
[Re: dilvoy]
#1589387
03/22/14 09:24 AM
03/22/14 09:24 AM
Guitar Jones
For the guys that don't want to change the low reverse band. I have Installed some B&M kits in some old 727's and always went and bought low reverse bands for the job, because the friction lining seemed to be made of some sort of paper and I was worried about damaging it when cleaning it. How do you clean it well without damaging it?
The only thing that will damage it is water. Mineral spirits, gasoline, diesel fuel, lacquer thinner nothing harms it but water.
[Re: ChrgrCuda]
#1589388
03/22/14 09:28 AM
03/22/14 09:28 AM
Guitar Jones
Nice try. I'll give you an "E" for effort. Sugar coat this turd however you like, however the customer is still inconvenienced by having to bring the vehicle back in AGAIN regardless if they have to pay or not. However I thank you for proving my point as to why Chrysler has pretty much the worst reputation in the industry when it comes to service. You just keep on replacing what is ABSOLUTELY is necessary. Another great reason as to why Chrysler has such a [Edited by Moparts - Family Friendly Site - Keep it clean] resale value as customers have experienced just what you described.
EVERY MANUFACTURER OPERATES THE SAME WAY not just Chrysler. Your outrage is misplaced.
[Re: Guitar Jones]
#1589389
03/23/14 07:18 PM
03/23/14 07:18 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
I used the original rear band in the 47RE I built for my 01 80K+ miles ago...(reason was that the hp/torque of my Cummins had been raised well beyond what the stock trans was designed to handle). Believe that core had 60k on it when I got it. I also reused the bearings, and all the planetary gears. Used the same pump, and did replace the input shaft and hub as the splines had some play in them, and of course, a new triple lock torque converter. Like a few others here.... I've been around the block a few times on these transmissions. You get to know what to look for, what gets changed, and what can be used again. Biggest reason for failure rate of those old trannys imho is the gawd awful amount of overlap they were programmed with from the factory..... and it was always funny how many of the clutch pack clearances were wrong. BTW a prolonged 1-2 shift I'd be looking pretty hard at the front band adjustment, and servo. Fwiw... I service my trans every 30k, my truck is a tool to pull my race trailer and boat.... and it does it well.
