Re: Mopar techs or parts guys i need help iden. this part
[Re: TX9H6E4CUDA]
#1588852
03/06/14 07:05 PM
03/06/14 07:05 PM
Challenger 1
Cincinnati, Ohio
I'm guessing fuel pump or sending unit. But I'm thinking fuel pump? Wow we have 07 300 that has been sitting all winter. I just charged the battery last weekend after my wife emptied the trunk so we could get to it. Why did your battery leak? makes me nervous.
[Re: stumpy]
#1588854
03/06/14 07:17 PM
03/06/14 07:17 PM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
Challenger1 https://board.moparts.org/ubbthreads/show...rue#Post8062943I don't know what caused the failure. Its a factory battery. I have tried to clean it off bit the part is so brittle it just falls apart if I even breath on it.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
[Re: TX9H6E4CUDA]
#1588855
03/06/14 07:25 PM
03/06/14 07:25 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
A battery temp sensor would be my guess, the temp of the battery is one factor in calculating the charging voltage.
"I think its got a hemi"
[Re: TX9H6E4CUDA]
#1588858
03/06/14 07:31 PM
03/06/14 07:31 PM
Posts: 3,842 Ohio
john55
Ohio
looks like a through body connector, are there wires connected on the bottom side under the trunk, possibly ABS... 2 twisted pairs of wires, I guess ABS.... , I'll look it up... That's an ABS thru body connector, the wire colors match up to rear ABS sensors , I'd just clean around the area, make sure the ABS light doesn't stay on after replacing the battery
[Re: john55]
#1588865
03/08/14 02:57 PM
03/08/14 02:57 PM
TX9H6E4CUDA
minnarusta
Ding ding ding I went to the fifth dealer and the guy found it......it can only be bought with a full harness. I was able to get another one off a car at a salvage yard. Thanks again fir the help!!!!!
