8 3/4 sure grip conversen hellp #1588715
03/06/14 05:39 AM
03/06/14 05:39 AM
Oly Wash
racerlall Offline OP
Oly Wash
Hi I have a 3:55 741 open and a suregrip carrier and I'm sure I saw where you could replace the open carrier with the suregrip one just not sure of the steps involved thanks fore looking E.
Re: 8 3/4 sure grip conversen hellp [Re: racerlall] #1588716
03/06/14 05:58 AM
03/06/14 05:58 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
do you have a dial indicator ??
I am truckless..
Re: 8 3/4 sure grip conversen hellp [Re: racerlall] #1588717
03/06/14 07:32 AM
03/06/14 07:32 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Pull out axles far enough to get the center section out - put the replacement in, I recommend cleaning, inspecting and repacking the axle bearings. Make sure that if in a 68 or earlier clutch type sure grip the button spacers are in place and then install the axles and adjust end play. as follows. http://www.moparts.org/Tech/Archive/axle/12.html
Re: 8 3/4 sure grip conversen hellp [Re: MoparforLife] #1588718
03/06/14 12:50 PM
03/06/14 12:50 PM
Oly Wash
Oly Wash
yes I do have a dial indicator and I know how to swap third member I'm talking about the center carrier in the gear set its self thanks fore looking E.
Re: 8 3/4 sure grip conversen hellp [Re: racerlall] #1588719
03/06/14 04:13 PM
03/06/14 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 8 3/4 sure grip conversen hellp [Re: racerlall] #1588720
03/06/14 06:00 PM
03/06/14 06:00 PM
Pull the third member and clean all the gear oil off of the ring and pinion, then measure the backlash in 4 places and write it down, Take the ring gear off of the open carrier and set the posi carrier in a cold place, set the ring gear on or near a stove so you can warm it up to 130 F to 200 F, be careful on handling it when hot Then slide the ring gear on the posi and get several ring gear bolts started and tighten, remember the ring gear bolts on 8 3/4 are all left hand threads , not standard right hand threads Once you get the ring gear mounted and torque all the bolts to 55 Ft lbs. set the carrier into the third member and adjust the adjusters so you get zero end play on the carrier bearings left to right . Once that is done move the carrier over to the passenger side by adjusting (tightening) and loosening the two adjusters until you get between .0015 to .0010 back lash, check the backlash in all four places again to make sure the ring gear run out does not exceed .002 runout If the ring gear run out exceeds .002 take it off the carrier amd move it 80 to 120 degrees on the carrier and check it again Once you get the ring gear run out where you want it with no carrier bearing preload, .0010 to .0015 backlash, then tighten the passenger side adjuster until you get the original back lash you had, + or- .0010 IHThs If you don't have a tool to use on the adjusters go buy one first, it will take a lot of preload on the passenger side adjuster to make the correct backlash come back, it might be okay to loosen the left adjuster between 1/8 to maybe 1/3 third of a turn on the left adjuster to get the backlash set properly, do that as a last resort though, crank on the passenger side adjuster as hard as you can first IHTHs, it really helps to have a factory service manual also
Re: 8 3/4 sure grip conversen hellp [Re: Cab_Burge] #1588721
03/07/14 03:35 PM
03/07/14 03:35 PM
Oly Wash
Oly Wash
cool just what I was looking fore thanks a lot
