70 to 71 Cuda Conversion Questions
#1588514
03/05/14 02:01 PM
03/05/14 02:01 PM
Posts: 42 Salt Lake City, UT
Turbo224
Salt Lake City, UT
Okay, I am in the process of converting a 70 cuda to a 71 and want to make sure I'm gathering the correct parts. Here is what I have so far.
-71 complete grill assembly -front valence -front valence insert -front parking lights -rear tail lights -fender gill weld-in inserts -duel headlight buckets -header panel (I believe the one I have is from a 72)
Here is a list of things I believe I am going to need that I don't have -front headlight wiring harness -hood/latch support -grill mounting hardware
What I need to know is what the difference is on the header panel between 71 and 72-74 and how to get my 72 panel to work? Also, I have a number of extra hood supports, I just need to figure out what the difference is between the 70 and the 71-74. And finally, will a 71 headlight wiring harness plug into the existing bulkhead plug on the firewall? Or will I need to modify it?
I'm sure I will be coming up with a lot more questions, so any help is appreciated. Thanks
Tyler Larsen~Salt Lake City
-1971 Plymouth Cuda 440-6pk Tribute
-1992 Dodge Daytona IROC R/T
-1989 Shelby CSX-VNT #153
Re: 70 to 71 Cuda Conversion Questions
[Re: crocha617]
#1588520
03/07/14 10:37 AM
03/07/14 10:37 AM
Posts: 234 Postville, IA
CudaDave7071
Postville, IA
The darker blue colored header panel in the picture is a 71 - the light blue one is a 72-74.
