Does adding L31 and AO1 delete V78 and scoops? #1588344
03/05/14 02:52 AM
03/05/14 02:52 AM
Phoenix - surface of the sun
nomore65BelvJim Offline OP
A simple yes or no will work. Thanks!
OK, OK...not so simple!
1969 Barracuda FB with the A57 383 'Cuda package.
Also has the AO1 light package, L31 turn signal light hood/fender.
Does the L31 option delete the hood stripes and scoops?
And the V78 longitudinal paint accent stripe delete. Is that deleted because of the A57 option due to the 383 tape nameplate?
TIA for any insight into this!
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: nomore65BelvJim] #1588345
03/05/14 04:37 AM
03/05/14 04:37 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NO!
1969 Barracuda
L31 is part of the A01 "light package"
V7_ is STANDARD on a Barracuda BH2_ ..... but is "deleted" (V78) when A57 is ordered
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: 6bblgt] #1588346
03/05/14 04:47 AM
03/05/14 04:47 AM
Thanks Dan.
Would you know what the "deleted" at the end of the A57 package description means then?
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: nomore65BelvJim] #1588347
03/05/14 04:50 AM
03/05/14 04:50 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: nomore65BelvJim] #1588348
03/05/14 04:57 AM
03/05/14 04:57 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
just a poor generic on-line decoder cut-n-paste swing & miss
DELETE STANDARD "accent stripes"
'69 Barracuda at HAMTRAMCK-HISTORICAL
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: 6bblgt] #1588349
03/05/14 05:20 AM
03/05/14 05:20 AM
Ise gots yous poor generic...RIGHT HEAAAA
So, the V78 is basically repeated with the "deleted" in the A57 description
Like the A01 lists the hood/fender turn signals in the description but its repeated again on the tag as L31? The redundancy is confusing!
Just for S&G's...Is there an option that would delete the scoops?
Thanks again Dan, and thanks to Barry too!
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: nomore65BelvJim] #1588350
03/05/14 05:26 AM
03/05/14 05:26 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A53 instead of the A57
Re: Does adding L31 and AO1 delete V78 and scoops? [Re: 6bblgt] #1588351
03/05/14 05:30 AM
03/05/14 05:30 AM
Nyuck nyuck nyuck
