starting line beam #1588341
03/05/14 02:45 AM
03/05/14 02:45 AM
Denver Co.
BadBelvedere Offline OP
Denver Co.
Does anybody know the height of the starting line beam? and the finish line beam. Also are stripe takers legal?
Re: starting line beam [Re: BadBelvedere] #1588342
03/05/14 05:13 AM
03/05/14 05:13 AM
What I remember after asking NHRA division Six tech. for the specs for the starting line is no higher than three inches to trip the starting line beams and eleven inches max center to center on the pre stage to the stage beams. I've heard, not told to me by any NHRA officials though, that the finish line beams are suppose to be no higher than six inches high maximum to trip the beams. Stripe takers are dependent on the class and track rules so ask your local tech. reps on that
Re: starting line beam [Re: Cab_Burge] #1588343
03/05/14 09:22 AM
03/05/14 09:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here you go. I believe the finish line is close to 5"
http://www.nhra.net/dragster/1999/issue25/Starting_Line.html
Doug
