big block oil pan #1588325
03/05/14 01:35 AM
03/05/14 01:35 AM
ky
68roadrunner Offline OP
ky
does anyone make an aluminum dragster pan with the kickout and fancy scrapers and baffles
or are these custom special order deals. thanks
Re: big block oil pan [Re: 68roadrunner] #1588326
03/05/14 02:05 AM
03/05/14 02:05 AM
Lots of choices out there, I like and use Charlies oil pans for my custom aluminum race pans Try 330-825-3586 as a CBR #
Re: big block oil pan [Re: Cab_Burge] #1588327
03/05/14 02:13 AM
03/05/14 02:13 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
I just got the exact pan you described. I oredered it from mancini but its a charlies pan. Look on mancini website and its on there.
Re: big block oil pan [Re: Joes66dart] #1588328
03/05/14 02:25 AM
03/05/14 02:25 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
My new pan, Charlie's from Mancini...
Re: big block oil pan [Re: Forest] #1588329
03/05/14 12:00 PM
03/05/14 12:00 PM
ky
ky
good looking pan
only two bolts on the side, wonder how good that seals?
Re: big block oil pan [Re: Forest] #1588330
03/05/14 01:36 PM
03/05/14 01:36 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
what's the rear depth on that pan?
thanks in advance
Joe
Without Data, you’re just another guy with an opinion.
Re: big block oil pan [Re: sr4440] #1588331
03/05/14 02:59 PM
03/05/14 02:59 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
thanks in advance
Joe
7" at the rear, Mancini says 6", kinda caught me off guard once I got it. I do think its better to have the separate lowered sump at the rear rather than solely relying on the trap door. FYI the rear sump by itself hold 2 full quarts.
Re: big block oil pan [Re: Forest] #1588332
03/06/14 12:32 AM
03/06/14 12:32 AM
ky
ky
thanks for the pics forest
i do like the idea of the separate sump, never saw one like that, alot of extra work but worth it.
how many qts. is it
wonder how many hp the kick out is worth
Re: big block oil pan [Re: 68roadrunner] #1588333
03/06/14 12:40 AM
03/06/14 12:40 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
how many qts. is it
10 quarts, I verified and when I had 10 quarts in it the level was around 1" below the screen...
Re: big block oil pan [Re: Forest] #1588334
05/07/14 11:56 AM
05/07/14 11:56 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
thanks in advance
Joe
7" in rear. what about the front? Thanks, Don
