Tranny fluid/filter change 2005 Magnu R/T #1588135
03/04/14 09:09 PM
03/04/14 09:09 PM
Canada
WO23Coronet Offline OP
Canada
Going to change the fluid/filter soon and am wondering if there is a drain plug on the T/C on the NAG1? Seems pointless to just drop the pan and change the fluid in there, while leaving just as much old stuff in the T/C and cooler lines, anyone got an answer? I checked the lxforums and couldn't find an answer
Re: Tranny fluid/filter change 2005 Magnu R/T [Re: WO23Coronet] #1588136
03/04/14 11:17 PM
03/04/14 11:17 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
No, NO drain plug. I just went thru all this in my 05 Hemi Wagon. I had to replace the converter . I learned alot about those transmission's last fall................they kinda suck! But, if there working there great!!
Re: Tranny fluid/filter change 2005 Magnu R/T [Re: High Impact] #1588137
03/05/14 12:49 AM
03/05/14 12:49 AM
Canada
Canada
What kind of issues did you have with your tranny that you had to change the T/C?
Re: Tranny fluid/filter change 2005 Magnu R/T [Re: WO23Coronet] #1588138
03/10/14 12:12 AM
03/10/14 12:12 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The important part of dropping the pan is to change the filter, clean the magnet and clean the bottom of the pan. The cooler, lines and torque converter are full of fluid but at least it's filtered fluid.
It's the same with engine oil change. Getting every last drop out of the engine is not important. Drain the bulk of it. Replace the filter and call it done.
