PAINT VS POWDER COAT TORSION BARS #1588116
03/04/14 08:52 PM
03/04/14 08:52 PM
Sweden
71redcuda Offline OP
Sweden
Hi,
Just want to check if there could be any problem to powder coat torsion bars instead of using regular paint..The heat and the torsion bars getting stressed when installed.. I understand the ends needs to be masked off so they fit in the control arms and frame.
Nicklas
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71redcuda] #1588117
03/04/14 11:26 PM
03/04/14 11:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
As a general rule I don't like powder coating, it promotes corrosion.
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71birdJ68] #1588118
03/04/14 11:31 PM
03/04/14 11:31 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Can you please explain that statement? Just curious.....
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71redcuda] #1588119
03/04/14 11:45 PM
03/04/14 11:45 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I do not know that powdercoat will flex very well.I believe it would crack and flake off.
Urethane paint would be my choice.
Re: PAINT VS POWDER COAT TORSION BARS [Re: Q5_Ed] #1588120
03/04/14 11:49 PM
03/04/14 11:49 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
It can chip,crack then moisture can get in between it and the metal and rust,much like undercoat,you have to repair any cracks,chips pronto.
Re: PAINT VS POWDER COAT TORSION BARS [Re: moparborn] #1588121
03/04/14 11:55 PM
03/04/14 11:55 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Sounds the same as paint to me.
**Photobucket sucks**
Re: PAINT VS POWDER COAT TORSION BARS [Re: 70Cuda383] #1588122
03/05/14 12:05 AM
03/05/14 12:05 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Yes is does but due to the thickness and stiffness of powdercoat,you do not see what is going on until the damage is pretty bad.
Re: PAINT VS POWDER COAT TORSION BARS [Re: moparborn] #1588123
03/05/14 12:51 AM
03/05/14 12:51 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Quite simply, paint is correct powder coating isn't.
Then you get into physical property variables or paint vs powder coating. I don't like the thick, gloppy, and usually overly glossy look of powder coating, especially on a restoration.
Re: PAINT VS POWDER COAT TORSION BARS [Re: Q5_Ed] #1588124
03/05/14 01:09 AM
03/05/14 01:09 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I just knew somebody would ask that, that's why I didn't say anything more. Paint is chemically bonded to clean metal, and powder coat is just plastic powder that is heated and melted. It's just laying there. If you have to do anything after powder coating something, like say ream a hole back to size cause the bolt won't fit anymore you have broken the seal, or sand the ends of the T bar the seal is broken, and moisture will wick up under it. In Alaska they had bush planes that had tube fuselages that looked ok, but upon inspection they found that most of a tube has rusted away under the powder, and it still looked ok. Some lawn mower companies have quit using it on the mower decks for the same reason.
It's ok on certain stuff, like my Hemi valve covers, but that is not K frames, T bars, or structural parts.
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71birdJ68] #1588125
03/05/14 01:13 AM
03/05/14 01:13 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Rust might be an issue where you live where your cars rot from the inside out but out here there is no difference between paint and powdercoat
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: PAINT VS POWDER COAT TORSION BARS [Re: ScottSmith_Harms] #1588126
03/05/14 03:20 AM
03/05/14 03:20 AM
Washington/Las Vegas
1971 Gran Coupe Offline
I agree with the correct aspect, but if you like powder coat use it. How many torsion bars have you seen rusted to unserviceable? And with the caliber of cars being fixed up, are they going to see much salt or corrosion sitting in the garage or at the local car show.
Re: PAINT VS POWDER COAT TORSION BARS [Re: AZ_A12_BEE] #1588127
03/05/14 10:08 AM
03/05/14 10:08 AM
P
PasiR Offline
PasiR  Offline
P
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71birdJ68] #1588128
03/05/14 08:49 PM
03/05/14 08:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The powdercoating industry has addressed those issues the last few years, assorted primers and rust preventive bases are/can be added before a part is powdercoated...
FYI I generally prefer to dip the torsion bars (after derusting/stipping) in POR-15 Chassis Black and let them drip dry horizontally for a factory appearance
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71birdJ68] #1588129
03/13/14 01:16 AM
03/13/14 01:16 AM
Jacksonville Florida
elitecustombody Offline
Did a thought cross your mind that maybe your powdercoater skips a few important steps in the process?
Properly done powdercoating should not chip,peel or crack.
Re: PAINT VS POWDER COAT TORSION BARS [Re: elitecustombody] #1588130
03/13/14 01:36 AM
03/13/14 01:36 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ever watch the chopper show with junior? After they get a frame power coated the bolts won't fit the holes, so what do they do? Take a drill bit and ream it, which brakes the seal.I was just saying it's ok on certain stuff. I don't have a personal powder coater,cause like I said, as a rule I don't like it.
To the OP have the TBs coated, and if they put to much on the ends, and they won't fit in the sockets, then what? Grind it off? Then you just broke the seal.
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71birdJ68] #1588131
03/13/14 01:59 AM
03/13/14 01:59 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The bars could be treated with an acid etch-ant high temp primer for corrosion resistance, the hex end can be "taped" off during the powder coat application, good communication to the coater as to your intended usage/application from the end user goes a long way in achieving the desired results/benefits
Re: PAINT VS POWDER COAT TORSION BARS [Re: DAYCLONA] #1588132
03/13/14 03:23 AM
03/13/14 03:23 AM
Sweden
Sweden
Great with all replies.. They ended up like this,dipped in paint.
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71redcuda] #1588133
03/13/14 03:14 PM
03/13/14 03:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Wow, I've never seen a "stock" pair that had that many drips!
Personally I don't care for powdercoat. I paint most things myself at my convenience. The finish is great. I can mask what I don't want covered. If it ever chips I can touch it up or redo it. And a good prep, epoxy prime and single stage is a pretty good coating.
As for the comments about "breaking the seal" - well, that will happen with just about any coating with any thickness ... unavoidable.
Re: PAINT VS POWDER COAT TORSION BARS [Re: 71redcuda] #1588134
03/13/14 11:00 PM
03/13/14 11:00 PM
ours had that many too.
