No spark from plug wires,possible problems?? #158791
11/29/08 01:11 PM
11/29/08 01:11 PM
Anonymous OP
Anonymous OP
It is a 74 440...
I took the coil wire off at the distributor cap and it is firing there when I try to crank it.It has NO spark at any of the plugs.What are the most likely problems and are there some type of tests to troubleshoot it? Thanks,Allen
Re: No spark from plug wires,possible problems?? #158792
11/29/08 01:24 PM
11/29/08 01:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Missing/broken rotor...
Re: No spark from plug wires,possible problems?? [Re: 1_WILD_RT] #158793
11/29/08 04:41 PM
11/29/08 04:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Or burned through rotor. (to ground)
Re: No spark from plug wires,possible problems?? [Re: buildanother] #158794
11/29/08 05:11 PM
11/29/08 05:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A - Rotor button - pull the rotor and see if theres hole burned in the center
B - bad cap ( not likely)
Re: No spark from plug wires,possible problems?? [Re: gtx6970] #158795
11/30/08 01:33 AM
11/30/08 01:33 AM
Anonymous OP
Anonymous OP
Re: No spark from plug wires,possible problems?? #158796
12/03/08 01:56 PM
12/03/08 01:56 PM
Anonymous OP
Anonymous OP
Replaced rotor button and distributor cap.Any ideas on how to test other components that could be faulty.As I mentioned before,it HAS a spark at the coil wire but NO spark at the plugs
Re: No spark from plug wires,possible problems?? #158797
12/03/08 02:16 PM
12/03/08 02:16 PM
Anonymous OP
Anonymous OP
what the heck is a rotor button? like a muffler bearing?
Re: No spark from plug wires,possible problems?? #158798
12/03/08 04:09 PM
12/03/08 04:09 PM
when you pul the coil wire out of the dist & hold it 1/4" from ground & crank w the key you have multiple regular sparks? You've replaced the cap/rotor button,that would only leave the plug wire(s)as you're going downstream from the cap to the plugs unless something is not copacetic with the new cap/rotorbutton(I like the sound of that) that you just replaced.
Re: No spark from plug wires,possible problems?? [Re: RapidRobert] #158799
12/03/08 04:21 PM
12/03/08 04:21 PM
Anonymous OP
Anonymous OP
i goggled rotor button since i didnt know what it was. appears to be what i call a rotor. with that in mind, maybe this will help
http://www.ehow.com/video_2327606_check-rotor-button.html
Re: No spark from plug wires,possible problems?? #158800
12/03/08 04:46 PM
12/03/08 04:46 PM
Cucu I thought you were just being a bit facetious on hump day. that's what they call a rotor over in England.
Re: No spark from plug wires,possible problems?? #158801
12/03/08 04:55 PM
12/03/08 04:55 PM
chicagoland,usa
chicagoland,usa
You GOGGLED a BUTTON?
Re: No spark from plug wires,possible problems?? [Re: buildanother] #158802
12/04/08 08:33 AM
12/04/08 08:33 AM
Anonymous OP
Anonymous OP
sure did. i thought i was missing something on my rotor (ok now im being facetious- more facetiouness to come in the next sentence). maybe an old racers trick- installing a button is good for .02 seconds or something.
Re: No spark from plug wires,possible problems?? #158803
12/04/08 09:06 AM
12/04/08 09:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Button is in the cap, not the rotor.
Since you replaced the cap and rotor that leaves the distributor not turning.
Are you getting more than one spark at the coil wire? Because if you are only getting one spark check to see if the distributor is actually turning.
Don't be the exception.
Re: No spark from plug wires,possible problems?? [Re: Supercuda] #158804
12/04/08 10:30 AM
12/04/08 10:30 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
rotor not turning.
Dumb question based on info above. Do you have electronic ignition? I assume not, but just to make sure.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: No spark from plug wires,possible problems?? [Re: Supercuda] #158805
12/04/08 11:08 AM
12/04/08 11:08 AM
Now we know for sure & it reminds me of my pre Mopar days when on an HEI the "rotor button" in the cap was replaceable. All that's left is for Allen to finish this out.
Re: No spark from plug wires,possible problems?? [Re: RapidRobert] #158806
12/04/08 11:40 AM
12/04/08 11:40 AM
Anonymous OP
Anonymous OP
not too sure about that. I googled it remember and the links all said it was the rotor itself.
see http://wiki.answers.com/Q/What_is_rotor_button
http://www.latemodelrestoration.com/iwwi...01&comp=LRS
Now I do admit, the named rotor button does seem more likely to describe the little round carbon button in the cap but that isnt what the web is point to. besides, that button isnt replaceable without replacing the cap.
to solve this the op needs to provide more info. answer the questions asked above and a solution can be found
Re: No spark from plug wires,possible problems?? #158807
12/04/08 02:00 PM
12/04/08 02:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well,your links are wrong, there is no button shown, especially in the last link.
While there might be an application that has the button on the rotor rather than the cap in the OP's setup it's in the cap.
In any case the point is moot as he has replaced the cap and rotor, with what one assumes to be hte right parts that fit properly. This should negate the "button issue".
That leaves ONE thing, the distributor is not turning. I ran into a situation where the rotor was not turning on a slant six, long story why but basically the owner was a chucklehead. The coil would spark once per "key on/key off" cycle. This was with an electronic ignition setup.
If the PO is getting only one spark from the coil wire it would point to that, if he is getting multiple sparks then it wouldn't point to it.
Re: No spark from plug wires,possible problems?? [Re: Supercuda] #158808
12/04/08 02:05 PM
12/04/08 02:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The button is the carbon button in the cap, most are solidly moulded into the cap but some are attached like an alternator brush with a copper strap & a spring, that style sometimes falls out & you get weak/no spark at the plugs...
& no rotor spinning = one spark...
Re: No spark from plug wires,possible problems?? #158809
12/04/08 02:34 PM
12/04/08 02:34 PM
Louisiana
duckblind Offline
duckblind  Offline
Louisiana
If it is an electronic ingition, it could be a bad electronic module. I had the same thing happen with a mallory unilite distributor.
Re: No spark from plug wires,possible problems?? [Re: 1_WILD_RT] #158810
12/04/08 03:00 PM
12/04/08 03:00 PM
Anonymous OP
Anonymous OP
im with you. I call the rotor a rotor and a cap a cap. calling a rotor a rotor button is a new one on me. I never had a name for the contact in the distributor
