Re: 2002 ram 1500 4.7 code help
[Re: earthmover]
#1588020
03/04/14 04:28 PM
03/04/14 04:28 PM
Guitar Jones
Which filter did you change and what brand?
[Re: Guitar Jones]
#1588021
03/04/14 04:35 PM
03/04/14 04:35 PM
Guitar Jones
The p0037 code is a bank 1 sensor 2 (downstream) o2 heater circuit code. Probably needs an o2.
The P0736 is gear ratio error in reverse I think. This could be caused by a partially clogged filter, the screw on filter in the pan. Use only a Mopar filter as we've had problems with some aftermarket ones.
[Re: earthmover]
#1588023
03/05/14 11:05 AM
03/05/14 11:05 AM
Guitar Jones
Also check your shifter adjustment and for loose bushings as not being properly in reverse could set that code too. Also possibly a shift lever position switch (prndl switch? I forget) or wiring.
[Re: Guitar Jones]
#1588024
03/05/14 08:01 PM
03/05/14 08:01 PM
Posts: 2,449 nc
earthmover
nc
[Re: earthmover]
#1588025
03/06/14 11:54 AM
03/06/14 11:54 AM
Guitar Jones
Yeah if the PCM is not seeing the switch input that it is in reverse when the manual valve is it will set that code. May just be a bad switch.
[Re: earthmover]
#1588027
03/10/14 10:34 AM
03/10/14 10:34 AM
Guitar Jones
anyway to check this??? been looking through the book I got and haven't found anything..is it called shifter switch???? thing is about to drive me crazy..thanks
You would need a DRB III to check it as far as I know.
