Re: what are these?
[Re: jlatessa]
#1587946
03/04/14 11:28 AM
03/04/14 11:28 AM
On my 69 Charger, one was used to hold the hoses together between the bracket on the inner fender and the holder up above the alternator so the hose did not sag and come in contact with the pulley or fan belt.
Re: what are these?
[Re: mickm]
#1587949
03/04/14 10:43 PM
03/04/14 10:43 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
You can study the Engine Compartment photos here: http://www.iccahome.org/Only a few of the metal straps show up. A pattern I see in those photos is this: If the heater nozzles on the firewall are inboard and near the valve cover (as on A body), some metal straps are shown. If the heater nozzles are outboard near the fender, other special heater hose brackets were used, and no metal straps are shown.
Re: what are these?
[Re: burdar]
#1587953
03/05/14 05:58 PM
03/05/14 05:58 PM
Posts: 4,179 California
mickm
California
My Challenger has a plastic strap on the inner fender that the hoses go through. It also has the bracket by the alternator.
different by year? i don't' see one in the pic above...
