What is a better mech. fuel pump for a 500" BB ? #1587208
03/03/14 12:39 AM
03/03/14 12:39 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I currently run this one:
http://www.summitracing.com/parts/hly-12-440-11/overview/make/dodge
It is the common Holley unit. I had some fuel delivery issues last year while breaking in the Lunati cam. Lately while running the car hard it has run out of fuel at WOT. The fuel pressure at idle is in the 7 range. At 3000 rpms in Park I can see the filter starting to empty out. The pressure slowly drops as well. I'm sure it is only worse when under a load while driving. The float level is dead center in the sight plug. I have a 3/8" fuel line from tank to carb.
I recall reading that there is a better flowing Carter pump available. Any comments on the Carter unit or others?
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587209
03/03/14 01:18 AM
03/03/14 01:18 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I run a Carter pump on my 470" street toy. I've had it spun up over 6K multiple times with no issues.I even feed it with 5/16" line. Take a look at your pump pushrod....maybe slightly worn,not stroking the pump as far as it should? Pressure no volume??
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587210
03/03/14 01:21 AM
03/03/14 01:21 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Mancini has those Carter pumps
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587211
03/03/14 01:23 AM
03/03/14 01:23 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
why not electric.if you got to spend money electric much better
Re: What is a better mech. fuel pump for a 500" BB ? [Re: 71birdJ68] #1587212
03/03/14 01:23 AM
03/03/14 01:23 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
yep..was just checking
http://chucker54.stores.yahoo.net/mechanical.html
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587213
03/03/14 02:11 AM
03/03/14 02:11 AM
I had some fuel delivery issues last year while breaking in the Lunati cam. Lately while running the car hard it has run out of fuel at WOT. The fuel pressure at idle is in the 7 range. At 3000 rpms in Park I can see the filter starting to empty out. The pressure slowly drops as well. The float level is dead center in the sight plug. I have a 3/8" fuel line from tank to carb.
What Dcuda said there is something else going on. We run a 360 stock car with an OE "airtex" mech pump (class rules)/5/16" line with NO starvation at 6200 RPM at WOT at the end of the straights. I ain't checked the psi (yet) with a gauge inside the car (did not have an isolator until now) & no direct fuel line to the inside of the car allowed but the eng does not lay down & in fact at ~5800-6K when it gets up on the "Hughes" cam it turns on like crazy. For you at 3K it for sure should not be running out of fuel & that's in Park at that (no load). Measure the pushrod/check the sock (if used) or there's a restriction somewhere (or the pump is shot) or possibly getting real hot or using E10 .
Re: What is a better mech. fuel pump for a 500" BB ? [Re: RapidRobert] #1587214
03/03/14 12:49 PM
03/03/14 12:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Any pump that works at all should be able to supply fuel to the engine with no load.
A good first step would be to run a hose from a can of gas to the inlet of the pump to see if that part works.
Master, again and still
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587215
03/03/14 04:37 PM
03/03/14 04:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Excellant timing.
I have a customer interested in this very issue.
Plan is go with a new push rod , a quality mech pump, stock fuel tank, 3/8 sender and lines and call it good .
Considering how often his car will see high RPM's I told him it would be fine ( may have to put a lower RPM chip in the MSD box as a just in case )
Re: What is a better mech. fuel pump for a 500" BB ? [Re: gtx6970] #1587216
03/03/14 08:14 PM
03/03/14 08:14 PM
I hear some of em are crap, find a good one (you might ask on here)
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587217
03/04/14 06:13 AM
03/04/14 06:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sent you a PM.
Re: What is a better mech. fuel pump for a 500" BB ? [Re: 451Mopar] #1587218
03/05/14 03:56 AM
03/05/14 03:56 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Sent you one back, 451 !
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Kern Dog] #1587219
03/05/14 10:10 AM
03/05/14 10:10 AM
The Edelbrock while expensive claims to be able to support 600HP--I have used with great success. You must pay attention to details and not choke it down with wrong fittings etc.
Re: What is a better mech. fuel pump for a 500" BB ? [Re: ] #1587220
03/05/14 05:43 PM
03/05/14 05:43 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Clay Smith mechanical pumps are very good. I have seen them used on a 8 second dragster.
Re: What is a better mech. fuel pump for a 500" BB ? [Re: ] #1587221
03/05/14 05:57 PM
03/05/14 05:57 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
x 2
I want my fair share
Re: What is a better mech. fuel pump for a 500" BB ? [Re: SomeCarGuy] #1587222
03/05/14 06:07 PM
03/05/14 06:07 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Same Carter here on my six pack 505 street toy from Mancini and i cant complain I use the stock fuel line that 440 six pack came whit and that inqludes the return line from vapor separator !
Re: What is a better mech. fuel pump for a 500" BB ? [Re: Mopar Guy] #1587223
03/05/14 09:21 PM
03/05/14 09:21 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I used my original 1970 440 six pack pump on my 496 stroker 6 pack without any issues whatsoever.
This is the land of the free because of the brave
Re: What is a better mech. fuel pump for a 500" BB ? [Re: 451Mopar] #1587224
03/05/14 10:41 PM
03/05/14 10:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pics of what I have. Ports blocked off for shipping.
Re: What is a better mech. fuel pump for a 500" BB ? [Re: ] #1587225
03/06/14 02:45 AM
03/06/14 02:45 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The Holley I have has a 5/16" outlet. I had to use an adapter to a 3/8" for the line to the carb.
