Oil press warning light question
#1587029
03/02/14 03:22 PM
03/02/14 03:22 PM
Posts: 1,532 off the grid
340B5
off the grid
I'm thinking of T-ing in between my gauge sending unit and block on my SB, and wondering if this works well?
Yeah, it's got a smallblock.
Re: Oil press warning light question
[Re: 340B5]
#1587030
03/02/14 03:32 PM
03/02/14 03:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Instead of a light, mount a ignition kill switch... if it drops below(we will say 15 psi) that it kills the ignition... a light will get your attentions but you would still need to kill the ignition
[Re: 340B5]
#1587031
03/02/14 04:28 PM
03/02/14 04:28 PM
Posts: 12,109 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I always do that in my cars. I get a sender in the 12#-15# range and get a small flashing LED from the local auto parts. The LED costs less than $5 and can be stuck in almost anywhere and can be seen even in daylight.
It will always get my attention and in time to get ahead of any potential damage.
Master, again and still
[Re: Cab_Burge]
#1587034
03/02/14 05:52 PM
03/02/14 05:52 PM
Posts: 834 Missouri
galen
Missouri
This is what I use on the boat for oil pressure and coolant temp. (Autometer pro lite warning system)from jegs or summit. You can buy the sensors in the pressure and temp range you want. I have it mounted in my field of vision and it shows up in bright sunlight. Plumbed in on a T with my guage sender. You don't want a boat shutting down on a pass.
