Re: 4.0 mods?
[Re: ahy]
#1587005
03/08/14 08:26 PM
03/08/14 08:26 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
They do indeed run forever, I worked at the Kenosha plant that made them they made millions of them and it was pretty much the same old cast iron 7 main bearing design since the old 258 and even back into the 50s/60s AMC straight 6.
I have had several go 300,000 miles plus without any sort of engine repairs except waterpumps. They are decent power wise, IMO a lot better than most mid sized SUVs as is I wouldn't mess with it as people have said there are really onlyminimal gains to be had without "building" one and spending $$$.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
Re: 4.0 mods?
[Re: dogdays]
#1587007
03/09/14 07:16 PM
03/09/14 07:16 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have done several stroker motors, here is what you are looking for. 1. 2000 and newer intake, 2. a crack free exhaust manifold, there are many listed on ebay that replace the stock one. 3. 96 or newer exhaust head pipe, you will recognize it because it goes infront of the oil pan. 4. You can put 5.7 hemi intake and exhaust valves in it for cheap, don't do a chevy valve conversion DAMHIK, 5. an oversize throttle body helps, 6. I use a 258 amc crank, 4.2 rods and then H802CP pistons that were cnc dished to lower the compression down to reasonable levels, offset grind the crank .020 and shave the block so you have a .000 deck height. 7. you want a 7120 casting head, they have the best flow, and with some minor porting and polishing you get a lot of flow improvements 8. and you can look into an adjustable fuel pressure regulator to compensate for the mods you have done....my 94 wrangler stroker acts like a v-8 but needs premium and my wife's 98 TJ is getting 19 mpg without a stroker, just the intake and exhaust manifolds. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
