Re: 70 Body ignition switch........
[Re: JeffRacerG]
#1586981
03/02/14 01:33 PM
03/02/14 01:33 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You got snookied on the switch and by the seller, IMHO your best bet would be to look at/replace the starter solenoid on the firewall, the terminal marked/stamped "G" is ground for the neutral safety switch located on the transmission (AUTOMATIC) or on the clutch pedal (MANUAL) corrosion/oxidation can sometimes cause intermitten problems starting the vehicle, plus check clean all connections to the battery, starter, starter solenoid, replace and wires/cables that are suspect....buy a voltmeter to check voltage and continuity In the pic below, the "G" terminal is the lower right brass blade terminal Mike
[Re: JeffRacerG]
#1586983
03/02/14 02:26 PM
03/02/14 02:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I know bad solenoid would cause no cranking, but would it cause no power at all at the switch? When I had this momentary issue, nothing that is on when the key is in the run position would work.
It could...if the main + post on the solenoid is giving up the ghost, the starter solenoid is a cheap and easy replacement
[Re: JeffRacerG]
#1586987
03/02/14 06:00 PM
03/02/14 06:00 PM
Posts: 5,445 So Cal
Sinitro
So Cal
1 point often overlooked when working on a 70 RR with 4 speed is the reverse lockout mechanism... Today most of these have been stripped out but the lever on the column, engine side may still exist. It was required in 70 and tied in with the ignition switch and column lock. It would push the transmission into reverse when the column was locked. The lever on the column usually was just setting down, but if if this by movement or vibration changes the column can lockup and the key won't move. The solution is to either take the column apart and remove the locking mechanism, strap down the lever in a down position so it doesn't move.. Just my $0.05...
