how to remove wheel locks? #158686
11/28/08 11:28 PM
11/28/08 11:28 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
socket can't be found,
Re: how to remove wheel locks? [Re: formula_s] #158687
11/28/08 11:33 PM
11/28/08 11:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Find a normal socket that is just abit too small to fit over the wheel lock, then using an extension on it, belt it on with a until the socket jams over the wheel lock.
And then hit it with the..
Re: how to remove wheel locks? [Re: formula_s] #158688
11/28/08 11:33 PM
11/28/08 11:33 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I usually hammer a tight fitting socket onto it and then spin it off with my impact. There are tools you can buy that do the same thing ($$). If you have to drill it off it can get messy. Also you may be able to order a new key if you don't need it right away.
Re: how to remove wheel locks? [Re: 10sec440] #158689
11/28/08 11:34 PM
11/28/08 11:34 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
haha you beat me.
Re: how to remove wheel locks? [Re: 10sec440] #158690
11/28/08 11:34 PM
11/28/08 11:34 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Same advice though
Re: how to remove wheel locks? [Re: OzHemi] #158691
11/28/08 11:38 PM
11/28/08 11:38 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Use a beater craftsman 12 point.
Re: how to remove wheel locks? [Re: buildanother] #158692
11/28/08 11:45 PM
11/28/08 11:45 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Beat on a piece of water pipe or cheap-o jack handle then use a pipe wrench, why jack up a socket?
I can't afford this. mark
Re: how to remove wheel locks? [Re: a12superbee] #158693
11/28/08 11:48 PM
11/28/08 11:48 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've done it many,many times, and only messed up the socket once, and they are Craftsman, so I just go change it for another one
Re: how to remove wheel locks? [Re: OzHemi] #158694
11/29/08 12:14 AM
11/29/08 12:14 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's the kind with the key pattern in the center just take a punch and drive it in. Then use a 3/8" extension as the key. I've done it a bunch of times on used cars. There is normally enough room between the end of the stud and the nut for the center to go in.
Re: how to remove wheel locks? [Re: stumpy] #158695
11/29/08 12:43 AM
11/29/08 12:43 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
A socket made for a oil pressure sender works perfectly. You don't have to pound it on too hard, most people can't tighten those lugs very well.
Re: how to remove wheel locks? [Re: farmington] #158696
11/29/08 12:54 AM
11/29/08 12:54 AM
Bellville, Mi.
tscuda Offline
tscuda  Offline
Bellville, Mi.
Summit sells something. Search for sum900460
Re: how to remove wheel locks? [Re: OzHemi] #158697
11/29/08 12:55 AM
11/29/08 12:55 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Yeah but the one I break is always the one I need. Like the 1/2 to 3/8's adapter you twist off instead just getting the socket.
Re: how to remove wheel locks? [Re: a12superbee] #158698
11/29/08 12:59 AM
11/29/08 12:59 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've got 3 or 4 of them..just in case
Re: how to remove wheel locks? [Re: formula_s] #158699
11/29/08 02:03 AM
11/29/08 02:03 AM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
Cover the wheel with some wax and then use additional 'non-flammable' material to shield it while I tack weld a socket extention with my mig welder to the top of the locknut. Use a ratchet and it comes right off. Use cutoff wheel on the tack and move to the next one. Doesn't take long to do, could have it all done before you can beat one up with a hammer.
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: how to remove wheel locks? [Re: 4boxers4] #158700
11/29/08 12:23 PM
11/29/08 12:23 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
depending on wheel design, it can be easily moved with an air chisel too.
It just depends on whether there is enough room to get the chisel on the edge of the nut.
Re: how to remove wheel locks? [Re: 4boxers4] #158701
11/29/08 12:23 PM
11/29/08 12:23 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I've welded lugs on the lugs and just wrenched them off. Seems I always have extra lugs laying around.
Re: how to remove wheel locks? [Re: snuggles] #158702
11/29/08 12:47 PM
11/29/08 12:47 PM
NH
72challorange Offline
He's Game
He's Game
NH
I used these last time. For the $$$ it was worth the lessened aggravation.
Tom
http://www.sears.com/shc/s/p_10153_12605_00947392000P
Re: how to remove wheel locks? [Re: formula_s] #158703
11/29/08 02:59 PM
11/29/08 02:59 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I've used vice-grips
Re: how to remove wheel locks? [Re: 72challorange] #158704
11/29/08 03:00 PM
11/29/08 03:00 PM
North 40
Cudaben Offline
Cudaben  Offline
North 40
Sears sells 2 sided sockets, instead of squaredoff inside edges (like say a 13/16 socket) it has reversed spiral extrusions that cut into the outside of the rounded wheel lock. Ive had a set of 3 for years and there very handy and impact ready.
Mopars collect the whole set
Re: how to remove wheel locks? [Re: Cudaben] #158705
11/29/08 04:18 PM
11/29/08 04:18 PM
San Antonio, Tx
bulletpruf Offline
bulletpruf  Offline
San Antonio, Tx
Well worth the $$$. Needed these to get the locking lugs off my GTX. They were on there very tight; would not come off after I beat a 12 point socket onto 'em.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
