48 r block question with 59 heads #1586864
03/02/14 01:54 AM
03/02/14 01:54 AM
CA.
RAY1969CARS Offline OP
CA.
48 r block question with w5 heads work if I use a w2 48 intake ?
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586865
03/02/14 02:05 AM
03/02/14 02:05 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would think the push rods would be a issue too. The lifters are moved in a 48* block. I would guess you could do it but would have to clearance heads for push rods.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586866
03/02/14 03:13 AM
03/02/14 03:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The push rods holes have to be REALLY opened up...
the difference is just the 48* lifter bores so if you
get the push rods to fit just put the W-5 intake on
it ... if its the tall block then it should go right
on but if its the short 9.2 deck its gonna take some
mill work to fit being that the heads are much closer
Re: 48 r block question with 59 heads [Re: MR_P_BODY] #1586867
03/02/14 03:24 AM
03/02/14 03:24 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
And if it's a 9.00 deck then even more milling of intake.
Re: 48 r block question with 59 heads [Re: 1967dartgt] #1586868
03/02/14 03:35 AM
03/02/14 03:35 AM
CA.
CA.
Sorry I for got to say it was a 9.2 how much milling are we talking ? With using a 48 degree w2 intake
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586869
03/02/14 10:31 AM
03/02/14 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know but if its made for a 9.2 to should
bolt on... your gonna have to check that
Re: 48 r block question with 59 heads [Re: MR_P_BODY] #1586870
03/02/14 03:13 PM
03/02/14 03:13 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ray didn't you pass on my 9.200 deck block because it was a 59 degree?
Now you want to put 59 degree heads on a 9.200 48 degree block?
Re: 48 r block question with 59 heads [Re: dizuster] #1586871
03/02/14 03:56 PM
03/02/14 03:56 PM
CA.
CA.
I not sure what I want lolo I just need a race block the will work with the lest amount of money
Im
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586872
03/02/14 04:03 PM
03/02/14 04:03 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have a 9.20 deck 59 r3 block that I would swap for a 48 if you want the only problem is I am in NJ
Re: 48 r block question with 59 heads [Re: NoFrills] #1586873
03/02/14 04:07 PM
03/02/14 04:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and I have a fully cnc'd X block tall deck with bushed lifer bores and 4 bolt mains. all machine work done by Dan at Performance Only from a virgin X block brand new and ready to go.
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586874
03/02/14 04:49 PM
03/02/14 04:49 PM
CA.
CA.
A std deck r block would be nice were are they all at ????
Im
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586875
03/02/14 09:18 PM
03/02/14 09:18 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
in my garage holding my workbench up.
Re: 48 r block question with 59 heads [Re: J_BODY] #1586876
03/02/14 09:23 PM
03/02/14 09:23 PM
CA.
CA.
Lol
Re: 48 r block question with 59 heads [Re: RAY1969CARS] #1586877
03/03/14 08:56 AM
03/03/14 08:56 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
We have a tall deck 48 degree block with w5's on it. Used the Indy intake and heads were clearanced for pushrods. Jesel rockers and crane roller lifters.
Re: 48 r block question with 59 heads [Re: vc360] #1586878
03/04/14 10:24 PM
03/04/14 10:24 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Same here!
Re: 48 r block question with 59 heads [Re: 72demon416] #1586879
03/04/14 10:36 PM
03/04/14 10:36 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Anybody use a 9.2 deck 48 block with a 59° W head??
