During of the the cold snaps we had here a few weeks ago when I started the neon the gauges jumped to full readings then stepped back to normal. The ABS, Trac off and Brake lights stayed on and now every time I start the car they come on in about 5 seconds and stay on until the key is cycled off. From what I've read the cluster may have learned this bad habit and it takes a DRBIII to reset it.
Will disconnecting the battery for a while also reset the cluster or is there any other way to clear the learned values.
