Re: Chopping bottom off of bellhousing 727
[Re: '72CudaRacer]
#1586424
03/01/14 06:12 PM
03/01/14 06:12 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
You have too if you run a Milodon Super Stock pan and want to put the covertor bolts in. I cut it back about 1", between the two lower cover plate bolt holes. Use a hole saw in the corners to make a nice radius, then remove the rest of it. Never had a problem.
Brian
![](/ubbthreads/images/graemlins/iagree.gif) That's how we did ours !
[Re: RockChip]
#1586427
03/01/14 06:32 PM
03/01/14 06:32 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
I have relieved mine also in a similar way but I wouldn't recommend hacking the entire bottom off like a GM trans. They were designed that way and still crack from time to time.
[Re: '72CudaRacer]
#1586431
03/01/14 10:53 PM
03/01/14 10:53 PM
Posts: 16,932 NC
440Jim
NC
Brian
Nice to know. It would be nice if the Milodon catalog mentioned this.
