Re: Crank trigger ???
[Re: RockChip]
#1586299
03/01/14 04:34 PM
03/01/14 04:34 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
It's just that easy. ![](/ubbthreads/images/graemlins/laugh2.gif) O.K. , it was for me , but I mounted the pick up bracket to a motor plate. I have a small block and use the ATI with a big block pattern.
[Re: Quicksilver440]
#1586305
03/01/14 07:53 PM
03/01/14 07:53 PM
Posts: 294 Minnesota
RockChip
Minnesota
Very nice Andy!!! But I just picked one up from a Moparts member ![](/ubbthreads/images/graemlins/boogie.gif)
[Re: dvw]
#1586308
03/02/14 11:41 AM
03/02/14 11:41 AM
Posts: 1,770 Pa
Wv68charger
Pa
Sotck Mopar kit on mine, like was mentioned it has both sets of holes. Doug
That's just awesome right there!
[Re: dvw]
#1586309
03/02/14 11:57 AM
03/02/14 11:57 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Post hijack in progress,,,Doug, I love the attention to detail with the orange. Looks great.
RIP Monte Smith
[Re: RockChip]
#1586313
03/02/14 08:56 PM
03/02/14 08:56 PM
Posts: 9,882 MI, usa
dvw
MI, usa
Dvw, is your alternator mount sorta home made too? Other than the water pump part. I have the same one but on passenger side. [/quote
The boss on the water pump was .750" diameter aluminum that sat flush on the lower bolt face of the water pump. It was welded to the pump housing to stabilize it. The motor plate was slotted by marking the radius with a pencil stuffed through the alternator mount hole and swinging the alternator off the water pump mount. I drilled a series of holes along the mark and connected them by hand with a die grinder. This curved slotted hole gives the belt adjustment. Then it's spaced out with .750" round stock drilled for a through bolt clamping it to the plate. Doug
