Measuring driveshaft #158628
11/28/08 09:15 PM
11/28/08 09:15 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I changed from a 727 to a 904 transmission in my 70 cuda and now need to get a longer driveshaft. I have one that just needs shortened but im not sure the best way to measure or how much play you should have. I do have a yoke for the 904 so i can use it to measure off of if necessary.
Re: Measuring driveshaft [Re: derekeh] #158629
11/28/08 09:37 PM
11/28/08 09:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
shove it all the way in pull it out 3/4 " now measure from center to center
I am truckless..
Re: Measuring driveshaft [Re: 340SHORTY] #158630
11/28/08 10:06 PM
11/28/08 10:06 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Same way I do it, and the local driveshaft shop says too..
Re: Measuring driveshaft [Re: OzHemi] #158631
11/28/08 10:20 PM
11/28/08 10:20 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Alright ill do it. Thanks a lot!
Re: Measuring driveshaft [Re: 340SHORTY] #158632
11/28/08 11:09 PM
11/28/08 11:09 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Is that measurement taken with the weight on the suspension?
Would make a difference
Re: Measuring driveshaft [Re: NTOLERANCE] #158633
11/28/08 11:24 PM
11/28/08 11:24 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
So if the car was supported by jack stands when measured and then lowered onto the floor with the weight on the suspension will the measurement be too short or too long? Seems like you would need a little more length once the weight was on the suspension...
Re: Measuring driveshaft [Re: wings471] #158634
11/28/08 11:50 PM
11/28/08 11:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
when the firestones meet the road....... loaded suspension..... on the ground..... as you would be driving down the road.... now is it clear????
I am truckless..
Re: Measuring driveshaft [Re: 340SHORTY] #158635
11/28/08 11:55 PM
11/28/08 11:55 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I don't have firestones, so how would I measure mine?
Re: Measuring driveshaft [Re: 340SHORTY] #158636
11/29/08 12:06 AM
11/29/08 12:06 AM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
Maybe if you would read/comprehend what I wrote... In what way will the measurement change..
(A) measured with car on jack stands
(B) measured with the suspension loaded
Now stay with me here.....longer or shorter? Now is that clear??
Re: Measuring driveshaft [Re: derekeh] #158637
11/29/08 12:33 AM
11/29/08 12:33 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Why not call and ask whoever will be shortening it what measurement they want?
When I called the place that shortened mine, they asked me to measure from the end of the trans to the flat surface of the yoke in the back.
Re: Measuring driveshaft [Re: 340SHORTY] #158638
11/29/08 01:47 AM
11/29/08 01:47 AM
& just put a pair of jackstands under the rear axle (instead of the framerails) to get a "loaded" reading or easier yet just slide a floor jack under the 3rd member(the center) & get the car high enough so you can get up in there & get a measurement.
Re: Measuring driveshaft [Re: RapidRobert] #158639
11/29/08 05:19 AM
11/29/08 05:19 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
With the weight on the rear end (jack stands) just measure from the tail of the trans, not including the seal, to the face of the rear yoke and subtract 3 1/2". This your C/L to C/L lenght, good luck.
Re: Measuring driveshaft [Re: tecmopar] #158640
11/29/08 09:36 AM
11/29/08 09:36 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
All of the tires of the car are sitting on 6X6 blocks so its easy to work underneath it for now and the full weight of the car is on the suspension just as if it were sitting on the ground.
Not to change the subject but anyone know what type of fluid and how much ill need for my 904? Has a stock pan and converter is empty.
Re: Measuring driveshaft [Re: RapidRobert] #158641
11/29/08 09:48 AM
11/29/08 09:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I hope you're not serious.
or, that your floor jack has mechanical safety catches on it to prevent it from collapsing.
the best way to do it would be to have it sitting on the ground, as it will travel down the road.
since most of us are thicker than 4" and can't reach under there to measure, the next best thing would be to put jack stands under the rear axle just inside the tires, and up front on the control arms, just inside the tires, this will make the car level and simulate "as it goes down the road."
**Photobucket sucks**
