mopar ecu?
#158615
11/28/08 08:51 PM
11/28/08 08:51 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
any one got a lead on schematics from OEM MOPAR ecus? stock,orange,gold box? i want to see why a box for more rpm cant be goog on the street. remember im from the semiconductor industry and dome 1000s of r&d for this very reason and every one has had to improve on the previous design yet satisf the present revision 100% in relibility otherwise it would lead to legal stuff
Re: mopar ecu?
[Re: dgc333]
#158617
11/29/08 10:35 AM
11/29/08 10:35 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Be simple enough to build a current limiting device to prevent the issues. Mopar did the ballast because it was cheap and more reliable than the solid state stuff available in the early 70's.
Re: mopar ecu?
[Re: Supercuda]
#158618
11/30/08 11:11 PM
11/30/08 11:11 PM
if you get one, could you let me know. ive been looking for one as well.
i actually have a pwb out of an old ecu that had the potting melt out of it. I could probably trace it out but im really lazy
Re: mopar ecu?
#158619
12/01/08 01:02 AM
12/01/08 01:02 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I had reverse engineered an old orange box several years ago, and put the schematic into orcad or pspice (don't remember which), but all that stuff is in storage from when I got divorced and sold the house. As I recall the circuitry was pretty simple. I think it had four basic sections: The internal voltage regulation for the ECU, the magnetic pickup input signal conditioning, a timming/dwell circuit, and the output circuit (basicall the large power transistor that connected the coils negative terminal to ground.) I don't recall the part used in the timing circuit, but it used a UJT (UniJunction Transistor) and SCR as the main semiconductors? If you Google UJT timing circuit you should be able to find some simular schematics.
