Re: Sandblasting - air compressor size [Re: paris401] #1585918
03/05/14 04:27 AM
03/05/14 04:27 AM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
Has anyone tried to "piggyback" two compressors together to increase cfms?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Sandblasting - air compressor size [Re: Fishmarket] #1585919
03/05/14 10:11 AM
03/05/14 10:11 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have an 80 gal compressor that puts out just over 23 cfm at 150psi I think. I have a grainger water filter right where you plug in the air hose and one right on the pressurized sand blaster tank. It would run all the time but it would keep up. I also have a blasting cabinet and it easily keeps up with that and will even shut off while I'm blasting. It is important to size your nozzle right for the cfm you are using.
TP tools has a lot of info on compressors and cabinets.
Re: Sandblasting - air compressor size [Re: rapom] #1585920
03/05/14 10:35 AM
03/05/14 10:35 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You THINK ? ... specs and complete details please ..
Re: Sandblasting - air compressor size [Re: dOoC] #1585921
03/05/14 08:47 PM
03/05/14 08:47 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
If you look at the diagram at the bottom of this page.
http://www.aircompressor.com/imc-piston.html
I have the 318v model with a 5HP Baldor motor. I didn't even think you could still buy them as I bought mine at an auction 15 years ago and the date of manufacture is 7/26/90
Mine still looks brand new and runs quieter than a lot of the box store vertical compressors.
I guess it puts out just under 23cfms but I'm not sure at what pressure. After I bought it, I lowered my max pressure to 150 since I don't need all that extra pressure and I'm sure it will extend the life of it.
Like I said it keeps up with my sandblasting.
The Belaire also looks cool.
Re: Sandblasting - air compressor size [Re: rapom] #1585922
03/07/14 01:56 AM
03/07/14 01:56 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I use a Ingersoll Rand 185 cfm rotary compressor for my blasting. its set at 125psi which is I have adjusted to 100psi at the pot. 90-ish at the nozzle.
Re: Sandblasting - air compressor size [Re: chrisf] #1585923
03/07/14 10:08 AM
03/07/14 10:08 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I also set my regulate my pressure blaster at 90psi and at 75psi at the cabinet.
