Re: Sandblasting - air compressor size
[Re: BeEtLeJuIcE !]
#1585901
03/01/14 11:34 AM
03/01/14 11:34 AM
Posts: 3,666 The Historic Hudson Valley
MONC
PRESSURE or gravity feed SB unit ?
Not sure , which would work best with what I have?
Not looking to blast too much with it, just small projects every once in a while.
[Re: BeEtLeJuIcE !]
#1585903
03/01/14 11:59 AM
03/01/14 11:59 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Air volume and sustained pressure is king when blasting.
I have a 5 or 6 HP with a 60 gallon (I'm pretty sure) tank Black Max and I only generate about 100 psi or so that I use in the way you are talking about not sure about your 5 lb 150 psi statement. I have had the $250 Harbour Frieght cabunet and a 80 lb gravity feed canister blaster. It will keep up with the cabinet fine but runs constantly when I am working, it works with the canister but will literally run it out of air in about 5 minutes which causes it to use more sand. It works like a b!tch out of the gate but when the pressure drops to 60-70 it is less effective, still works just a notable differents, when I recognize it I stop and let the compressor pump up. 5 minutes may seem like a long time but it really isn't when you are blasting larger objects with less than optimal pressure. I could increase it's time span by added another storage tank but really haven't needed/choosen to do it. It definitely isn't good for the compressor.
If/when I have to buy a new compressor I would go with no less than an 80 gallon tank but really as big of a tank as I could afford at the time, even consider refurbushing an old gas station compressor ( I actually have an old dealership compressor I need to redo).
Hope this helps.
Careful, your character's showing!
[Re: MONC]
#1585905
03/01/14 12:20 PM
03/01/14 12:20 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
That helps put things in perspective, thanks. My compressor is small not sure how many gallon but I know it's not anywhere near 80 like yours. Doesn't sound like mine will do the job no matter what kind of sandblasting unit I get.
You CAN make it work if you get HUGE air storage. My past operation required 125 psi at 21 cfm for continuous usage BUTTT I never used the equipment that way. I "needed" a 10-15 HP unit to do that. But I used a 5 HP unit with almost 200 gallons of air storage.
Just find a bigger air tank to hook into your compressor system. It will work fine in spurts.
[Re: MONC]
#1585906
03/01/14 12:20 PM
03/01/14 12:20 PM
mopar346
It probably will for about 30 seconds.
[Re: MONC]
#1585907
03/01/14 02:26 PM
03/01/14 02:26 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Big. Real Big. Whatever size you can afford save your money and get one bigger yet. Nothing will bring a compressor to it's knees like sandblasting.
[Re: MONC]
#1585908
03/01/14 03:44 PM
03/01/14 03:44 PM
Challenger 1
Cincinnati, Ohio
Do you need a large air compressor to sandblast effectively? I have a small 6 lb 150 psi compressor, will it work effectively to sandblast rust off of say ,axles, manifolds, front end components etc.. ?
And if so, anyone have any recommendations of home sandblasting kits ?
Yes. No.
Got any links or pictures of your air compressor...6 lb? what's that mean?
Even a true 5 horse 80 gallon tank will not keep up, with a gravity feed or pressure pot blaster.
As cheap as a pressure pot is from HF, why would you invest your money in gravity fed deal?
But I would not spend 100 bucks on the one from HF, I would spend 400 bucks for 90 pounder from TP tools or some place like that. It's a way better deal and a lot's more blaster that will last a lifetime and be easier to use and be a ASME tank.
Sure a 5 horse 80 gallon tank will allow you to do small stuff, but not really well and you waste a lot of time and media like what was said above. My 5hp 80 gal tank comes on with in 1-2 minutes of me using my blast cabinet and never goes off while I''m using it. That means it struggling to keep up. Using my pressure pot blaster outside in the parking lot, I'm out of enough efficient air within 1-2 minutes tops, 5 minutes is a long time.
And I can promise you, that you gain nothing by adding storage tanks, you are truly limited by the output of the compressor, nothing can make up for that.
More storage tanks only prolongs the compressor coming on during which time your wasting sand and time with a lower output pressure. Then when the compressor does kicks on you have to wait even longer until you get to full pressure again. It's a losing battle and can't be won with additional storage tanks. It all works out the same in the end.
If you have a lot to do, your time and money ahead to rent a tow behind diesel compressor like they use for jack hammers. Minimum 100CFM
[Re: Challenger 1]
#1585909
03/01/14 04:08 PM
03/01/14 04:08 PM
Posts: 597 Lost in the 70's
440gtx6
Lost in the 70's
I'm kind of in a similar situation, I just bought a Bad Boys Blaster Tornado series 125 lb pressure pot ($300) and have been looking for a compressor. Haven't seen a good deal on a engine powered compressor in some time and I'd rather not rent because I plan to add a blast cabinet too for frequent usage.
Since I'm on single phase power looks like 10 HP motor is as big as I can go. I see the Polar Air Eaton compressors out there more reasonably priced and they claim 35 scfm @ 175 psi ($2500).
Would that keep up reasonably well?
69 EF8 GTX 440 auto 72 EB5 RR/GTX 440 auto 70 EW1 GTX 440-6 4 spd 70 EF8 Satellite 318 auto (452 coming soon) 70 FK5 Satellite 318 auto 71 FC7 Cuda 340 4 spd
[Re: 440gtx6]
#1585910
03/01/14 04:17 PM
03/01/14 04:17 PM
Challenger 1
Cincinnati, Ohio
I would say yes, 35CFM should be enough. That sounds like a killer compressor. I was considering a 7.5 HP electric before going diesel.
100 is over kill and is usually the smallest of the tow behinds? But I'm not sure of that?
I rented this one(100 CFM) I bet 10 or more times from the tool rental and then asked how much to buy it? I can't remember exactly how much it was, as it's been 10 or more years ago, it was around 3 grand I believe? Now I have it and have done countless larger jobs with it. Paid for it's self a long time ago.
[Re: Challenger 1]
#1585913
03/01/14 04:26 PM
03/01/14 04:26 PM
440gtx6
Lost in the 70's
Yea, I've been looking for a gas or diesel on craiglist for some time and they're either worn out junk for $2-3K or $6K or more for a decent used one.
