Page 2 of 4 1 2 3 4
Re: 070 clutch fan resto info [Re: autoxcuda] #1585773
03/12/14 06:01 AM
03/12/14 06:01 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
i know the repro isnt oe correct but i dont think you can see the face of it when on the car, and it does look alot better then the year one version
so for an almost $500 difference, i think for what my car is, the $200 repro will suit my car
thanks for your help
Exactly. And most every car I know that gets a clutch fan also get a fan shroud. So it's about impossible to see the face.
But you can see the fins on the back and side of the fan clutch. But it looks like those features are real close to OE??
Or, just pickup a Hayden version for $50.00 if you can live with it.....or buy the Mopar Performance Fan/clutch package for $100 or so. Though it's not a thermal clutch. But, I believe the fins look similar to the originals.
Re: 070 clutch fan resto info [Re: 1972CudaV21] #1585774
03/12/14 10:56 AM
03/12/14 10:56 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Use the Hayden 2765 for the $50.00 like he said. It is a thermal but you cant see the front of it which is also one of your points. DO NOT use the Mopar performance kit. It is 3 5/8" tall which will not fit most of the performance cars. It is patterned off a Dodge van with a 6 cyl.
Bob
Re: 070 clutch fan resto info [Re: radiatorman] #1585775
03/12/14 12:53 PM
03/12/14 12:53 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
From the pics i found of the Hayden 2765, it has slotted bolt holes and the fins dont look like original
i'd like it to be close at least
the hayden unit screams incorrect, while the $200 repro looks good when its installed on the car at least
when i said it my car wasnt oe, it isnt, but at least with the repro fan drive it will look correct when you open the hood and i dont care about those who pull out a mirror on a stick to check the front of it
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585776
04/05/14 01:32 PM
04/05/14 01:32 PM
NY
moparmatt0 Offline
moparmatt0  Offline
NY
L have been calling that 401-314-6811 number for pampered vettes and have not herd back from him?
Re: 070 clutch fan resto info [Re: moparmatt0] #1585777
04/05/14 02:14 PM
04/05/14 02:14 PM
california
Mr D21 Offline
Mr D21  Offline
california
email him...
Re: 070 clutch fan resto info [Re: Mr D21] #1585778
04/05/14 06:38 PM
04/05/14 06:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
He answered my email today, he shipped my clutch back today.
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585779
04/06/14 12:47 PM
04/06/14 12:47 PM
S.W. Florida
blkbee6pack Offline
blkbee6pack  Offline
S.W. Florida
Do they use the same orange or red seal?
Re: 070 clutch fan resto info [Re: blkbee6pack] #1585780
04/06/14 01:35 PM
04/06/14 01:35 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
I just got a "070" back from them and they do not use the correct colored seal(black) and the original aluminum finish is now the "Eastwood" special aluminum color.Otherwise the front ridge is correct looking and looks nicer then Fred's.I was not that impressed enough to change out the one I had Fred do.I had to "fluffed" up the fins to make them appear more correct on his also.So if anybody is looking for a fresh "070"......
Re: 070 clutch fan resto info [Re: 44D6PAKCUDA] #1585781
04/06/14 02:16 PM
04/06/14 02:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
So he paints them, not plated?
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585782
04/06/14 02:27 PM
04/06/14 02:27 PM
california
Mr D21 Offline
Mr D21  Offline
california
Oh great - I sent him 2 to restore...
Re: 070 clutch fan resto info [Re: Mr D21] #1585783
04/06/14 04:04 PM
04/06/14 04:04 PM
The face is plated(gold zinc,and stamped with part number and date code(incorrect fonts)but the aluminum part(body/fins)are painted silver instead of trying to lightly bead blast or some method to bring back the original finish of the aluminum.I know easier said then done,but Jim at Dixie does something similar to the alt and starter housings.
Re: 070 clutch fan resto info [Re: 44D6PAKCUDA] #1585784
04/06/14 04:52 PM
04/06/14 04:52 PM
california
Mr D21 Offline
Mr D21  Offline
california
please post some pics !!!
Re: 070 clutch fan resto info [Re: Mr D21] #1585785
04/06/14 05:41 PM
04/06/14 05:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I beleive Jim actually dichromate dips the alternators, this wouldn't be the right way to restore those clutch fins. The difficulty would be treating the two surfaces sepperately. The fins should be raw cast aluminum which could be accomplished a few different ways depending on the initial condition of the fins. The face plating could be done first, then coated with liquid rubber to protect it, then the fins restored, then remove the rubber and finallty, ink stamp date codes. PIA but could be done. The wrong color seal is the real detail issue IMO.
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585786
04/07/14 10:11 PM
04/07/14 10:11 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Vinny refinished my aluminum casting without any paint....I'm not sure about the seal. I'd have to check on that.
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585787
04/07/14 10:14 PM
04/07/14 10:14 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Liquid rubber??? I believe he removes the face plate, replates and uses some type of solder or something to reattach.
Re: 070 clutch fan resto info [Re: 1972CudaV21] #1585788
04/07/14 10:42 PM
04/07/14 10:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I received mine today. The seal is black, the face plated is gold/plated, the aluminum isn't painted, it's raw aluminum. The ink stamping font is wrong as Jim mentioned but I can fix that, it looks nicely done overall.
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585789
04/07/14 10:45 PM
04/07/14 10:45 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Mine is not the "070", rather it's the 1971 Hemi one. Can you post some pics? I'll try to post some as well to compare the finish.
Re: 070 clutch fan resto info [Re: 1972CudaV21] #1585790
04/07/14 11:01 PM
04/07/14 11:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585791
04/07/14 11:02 PM
04/07/14 11:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 070 clutch fan resto info [Re: ScottSmith_Harms] #1585792
04/08/14 09:46 AM
04/08/14 09:46 AM
After looking closer at the clutch I got back,I think Scott is correct that the body(fins) of the clutch are blasted and not painted as I first posted.They just don't have,and I know it's almost impossible to get the original finish on aluminum.Almost looks to smooth and silver.Otherwise the front plate and reproducing the correct looking ridge is perfect.
Page 2 of 4 1 2 3 4
