Page 3 of 3 1 2 3
Re: Motor oil in trans [Re: Supercuda] #158541
12/07/08 06:30 PM
12/07/08 06:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Whenever this is debated the seal compatibility issue usually arises but, in the case of Mopar, take a look at the part numbers of some of the internal seals in the steering box and pump; same part numbers for back in the day when ATF was the recommended fluid for P/S and the newer ones that specify P/S fluid only.
Re: Motor oil in trans [Re: John_Kunkel] #158542
12/07/08 09:03 PM
12/07/08 09:03 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Like someone said earlier,run two pumps with each,you'll see the difference.nothing to do with seals.
Re: Motor oil in trans [Re: I go fast] #158543
12/08/08 06:30 PM
12/08/08 06:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A higher detergent fluid might take on a black color after a while but that doesn't mean it's a problem.
Re: Motor oil in trans #158544
12/08/08 07:01 PM
12/08/08 07:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Also,put your motor oil in anything but a 904/727 and see how long it lasts.Even Type F is not recommended.
The guy that does my trannies(and is one of the leading performance trans builders in the country , and has been for 30 years)said not to run anything BUT type f in the trannie
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Motor oil in trans [Re: fastnos] #158545
12/08/08 11:13 PM
12/08/08 11:13 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
Was in the Air Force for 20 years, as a Vehicle Mechanic. Most of the larger trucks that had Allison transmissions in them, used 10 Wt (Hydraulic oil). Never had any major failure that I can remember because of the fluid. I know it's not engine oil, but it's along the same lines with different characteristics.
Before the electronic controlled tranny era it was common to use 15W-40 or 30 motor oil in Allison trannys. It was Allison approved oil as long as it was classfied as a "C4" fluid.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Motor oil in trans [Re: origcharger] #158546
12/09/08 11:08 AM
12/09/08 11:08 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Everyone is free to make their own choice.I have yet to see a automobile manufacturer tell you in their owners manual that you can substitute one for the other in either the engine or transmission.They are very specific in what should be used under any conditions.This is about motor oil in transmissions,not power steering or brake system.Also,show me a oil manufacturer that has their product labeled for use in either one.Each is a specific application.Just because someone has done it in the past and had no problems doesn't say that is the thing to do.It would take a side buy side comparison over a long period of time to actually determine what effect each would have in either case.I have seen many automatic transmissions from different manufacturers with well over 200K miles that never had a fluid change and continue to run smoothly.Transmission fluid change is one of the most neglected maintenance recommendations on a vehicle but they still work.Its your car,your money and your choice,do as you see fit.Myself,I'll use the product for each application that suits my needs best and use that product.Its worked for years.
"Carry on"
Re: Motor oil in trans [Re: I go fast] #158547
12/09/08 03:47 PM
12/09/08 03:47 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I wonder how many of these 'transmission builder experts' that say use this or that but not *this* or *that* have done any true long-term scientific-based testing? I wonder how many of them mix-n-match multiple variables and then pull a conclusion out on the other side???
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Motor oil in trans [Re: I go fast] #158548
12/09/08 04:33 PM
12/09/08 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If everybody followed the manufacturer's recommendations there would be no hotrodding and forums like this wouldn't exist.
Re: Motor oil in trans [Re: John_Kunkel] #158549
12/10/08 02:15 AM
12/10/08 02:15 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
the reason the marv booth guy recommended using some motor oil with ATF was heat related. It would still lubricate at a higher temps when ATF was useless as a lubricant. Seems like he said 16 to 32 oz. depending on how hard the transmission was used. I have put 16 oz. in everything for over 20 years.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
Page 3 of 3 1 2 3
