Wheel stud replacement on full time D44 #1585260
02/28/14 07:10 AM
02/28/14 07:10 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I think I already know the answer to this, but I was hoping maybe someone might know a trick to doing this.
Can a wheel stud be replaced without removing and disassembling the hub?
78 HD D44 front
Re: Wheel stud replacement on full time D44 [Re: hp383] #1585261
02/28/14 12:25 PM
02/28/14 12:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've had a couple of those all apart to install that manual hub kit, but I would bet that you still have to pull that bearing all apart to get at the studs. Saw a dealer guy pull just the rotor off after removing the big nut, and that was using that big puller that anchors to the studs and pushes on the axle stub itself. Just don't know if you can put it back together without removing the 6 bolts and retainer for re-assembly.
Re: Wheel stud replacement on full time D44 [Re: hp383] #1585262
03/01/14 12:15 AM
03/01/14 12:15 AM
N
NITROUSN Offline
NITROUSN  Offline
N
No. That's another joy of having that style full time junk.
