Re: Removing powder coating from a steel rim
[Re: moparply]
#1585118
02/27/14 11:53 PM
02/27/14 11:53 PM
Posts: 784 Florida
cbusters
What is the best way to remove powder coating from a steal rim? Glass beading? Chemical strip/dip? Etc
It's on there pretty thick.
Thanks?
Never tried it, but I read that gasket remover would do it.
[Re: Tropicalcats]
#1585123
02/28/14 11:58 AM
02/28/14 11:58 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I know I'm a hammerhead some days, but they are steel rims, snad blast them. Nothing with too much pressure, work at angles and don't stay on one spot too long. You really aren't gonna pit a steel rim to any degree so why fit it, after all they were more than likely blasted before the powder was applied.
Careful, your character's showing!
[Re: moparply]
#1585125
02/28/14 05:57 PM
02/28/14 05:57 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Just a thought. If you've a powder coater in your area, call them and see if they've got a burn off oven. That will remove the paint very nicely and be a lot less work than chemical stripping. We take walk in work like that all the time. And no, the heat of the burn off oven won't warp or hurt a steel rim. We typically charge $20-30 to do this.
You can't do this on aluminum rims by the way, unless you'd like to receive a pile of melted aluminum back.
Lead, follow or get the hell out of the way
