Removing powder coating from a steel rim #1585116
02/27/14 07:17 PM
02/27/14 07:17 PM
NJ
moparply Offline OP
moparply  Offline OP
NJ
What is the best way to remove powder coating from a steal rim? Glass beading? Chemical strip/dip? Etc
It's on there pretty thick.
Thanks?
Re: Removing powder coating from a steel rim [Re: moparply] #1585117
02/27/14 07:20 PM
02/27/14 07:20 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Aircraft paint stripper works well but can take some time.
Re: Removing powder coating from a steel rim [Re: moparply] #1585118
02/27/14 11:53 PM
02/27/14 11:53 PM
cbusters Offline
cbusters  Offline
Thanks?
Never tried it, but I read that gasket remover would do it.
Re: Removing powder coating from a steel rim [Re: AAR#2] #1585119
02/27/14 11:59 PM
02/27/14 11:59 PM
MI
scoty Offline
scoty  Offline
MI
Sometimes it helps to sand the surface w/ course sand paper to open the coating, before applying the stripper.
Scott
Re: Removing powder coating from a steel rim [Re: scoty] #1585120
02/28/14 12:09 AM
02/28/14 12:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Permatex gasket remover !!!
Re: Removing powder coating from a steel rim [Re: Stanton] #1585121
02/28/14 12:15 AM
02/28/14 12:15 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
So why are you removing the powder?
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Removing powder coating from a steel rim [Re: Stanton] #1585122
02/28/14 10:21 AM
02/28/14 10:21 AM
Tropicalcats Offline
I agree
Permeated gasket remover works great!
I have also blasted it off with black aluminum oxide.
Re: Removing powder coating from a steel rim [Re: Tropicalcats] #1585123
02/28/14 11:58 AM
02/28/14 11:58 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I know I'm a hammerhead some days, but they are steel rims, snad blast them. Nothing with too much pressure, work at angles and don't stay on one spot too long. You really aren't gonna pit a steel rim to any degree so why fit it, after all they were more than likely blasted before the powder was applied.
Careful, your character's showing!
Re: Removing powder coating from a steel rim [Re: moparply] #1585124
02/28/14 12:34 PM
02/28/14 12:34 PM
NJ
moparply Offline OP
moparply  Offline OP
NJ
Thanks for the replies. I wanted to remove the coating because it was put on very thick and it filled in the numbers on the rim. I will give the paint stripper a try. Thanks!
Re: Removing powder coating from a steel rim [Re: moparply] #1585125
02/28/14 05:57 PM
02/28/14 05:57 PM
Minnesota
peabodyracing Offline
Minnesota
Just a thought. If you've a powder coater in your area, call them and see if they've got a burn off oven. That will remove the paint very nicely and be a lot less work than chemical stripping. We take walk in work like that all the time. And no, the heat of the burn off oven won't warp or hurt a steel rim. We typically charge $20-30 to do this.
You can't do this on aluminum rims by the way, unless you'd like to receive a pile of melted aluminum back.
Lead, follow or get the hell out of the way
Re: Removing powder coating from a steel rim [Re: AAR#2] #1585126
03/01/14 03:03 AM
03/01/14 03:03 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
X2 on the aircraft stripper. When I used it on powder coat, it ate the stuff right off no sweat.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
