And you thought WD40 was only for rusty bolts. #1584867
02/27/14 09:56 AM
02/27/14 09:56 AM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
What IS The Main Ingredient of WD-40?
Before you read to the end, does anybody know what the main ingredient of WD-40?
No Cheating.....
WD-40 ~ Who knew!
I had a neighbor who bought a new pickup.
I got up very early one Sunday morning and saw that someone had spray painted red all around the sides of this beige truck (for some unknown reason).
I went over, woke him up, and told him the bad news.
He was very upset and was trying to figure out what to do....
probably nothing until Monday morning, since nothing was open.
Another neighbor came out and told him to get his WD-40 and clean it off.
It removed the unwanted paint beautifully and did not harm his paint job that was on the truck. I was impressed!
WD-40 who knew?
"Water Displacement #40".
The product began from a search for a rust preventative solvent and degreaser to protect missile parts.
WD-40 was created in 1953, by three technicians at the San Diego Rocket Chemical Company.
Its name comes from the project that was to find a 'Water Displacement' Compound.
They were finally successful for a formulation, with their fortieth attempt, thus WD-40.
The 'Convair Company' bought it in bulk to protect their atlas missile parts.
Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you.
When you read the 'shower door' part, try it.
It's the first thing that has ever cleaned that spotty shower door.
If yours is plastic, it works just as well as on glass.
It's a miracle!
Then try it on your stove-top.
It's now shinier than it's ever been.
You'll be amazed.
WD-40 Uses:
1. Protects silver from tarnishing.
2. Removes road tar and grime from cars.
3. Cleans and lubricates guitar strings.
4. Gives floor that 'just-waxed' sheen without making them slippery.
5. Keeps the flies off of Cows, Horses, and other Farm Critters, as well. (Ya gotta love this one!!!)
6. Restores and cleans chalkboards.
7. Removes lipstick stains.
8. Loosens stubborn zippers.
9. Untangles jewelry chains.
10. Removes stains from stainless steel sinks.
11. Removes dirt and grime from the barbecue grill.
12. Keeps ceramic / terracotta garden pots from oxidizing.
13. Removes tomato stains from clothing.
14. Keeps glass shower doors free of water spots.
15. Camouflages scratches in ceramic and marble floors.
16. Keeps scissors working smoothly.
17. Lubricates noisy door hinges on both home and vehicles doors.
18. It removes that nasty tar and scuff marks from the kitchen flooring.
It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off.
Just remember to open some windows if you have a lot of marks.
19. Remove those nasty Bug guts that will eat away the finish on your car if not removed quickly!
20. Gives a children's playground gym slide a shine for a super fast slide.
21. Lubricates gearshift and mower deck lever for ease of handling on riding mowers...
22. Rids kids rocking chair and swings of squeaky noises.
23. Lubricates tracks in sticking home windows and makes them easier to open.
24. Spraying an umbrella stem makes it easier to open and close.
25. Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26. Restores and cleans roof racks on vehicles.
27. Lubricates and stops squeaks in electric fans.
28. Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29. Lubricates fan belts on washers and dryers and keeps them running smoothly.
30. Keeps rust from forming on saws and saw blades, and other tools.
31. Removes grease splatters from stove-tops.
32. Keeps bathroom mirror from fogging.
33. Lubricates prosthetic limbs.
34. Keeps pigeons off the balcony (they hate the smell).
35. Removes all traces of duct tape.
36. Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37. Florida's favorite use is: 'cleans and removes love bugs from grills and bumpers.'
38. The favorite use in the state of New York, it protects the Statue of Liberty from the elements.
39. WD-40 attracts fish. Spray a little on live bait or lures and you will be catching the big one in no time. Also, it's a lot cheaper than the chemical attractants that are made for just that purpose.
Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
40. Use it for fire ant bites. It takes the sting away immediately and stops the itch.
41. It is great for removing crayon from walls. Spray it on the marks and wipe with a clean rag.
42. Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and rewash. Presto! The lipstick is gone!
43. If you spray it inside a wet distributor cap, it will displace the moisture, allowing the engine to start.
P.S.
As for that Basic, Main Ingredient.......
Well.... it's FISH OIL....
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: And you thought WD40 was only for rusty bolts. [Re: pittsburghracer] #1584868
02/27/14 10:06 AM
02/27/14 10:06 AM
tboomer Offline
tboomer  Offline
John..I have used to help take off decals and to take off rubber on my quarters from burnouts. I also have heard that Chapper uses it quite a bit!!
Re: And you thought WD40 was only for rusty bolts. [Re: tboomer] #1584869
02/27/14 10:27 AM
02/27/14 10:27 AM
PA.
"Little"John
"Little"John
PA.
I know I buy it by the gallon. I mix it with a little bit of transmission fluid for keeping my carbide burrs clean on aluminum heads and cool on cast iron heads.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: And you thought WD40 was only for rusty bolts. [Re: pittsburghracer] #1584870
02/27/14 11:58 AM
02/27/14 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try the new rust penetrant.It works great.Rocky
Chrysler Firepower
Re: And you thought WD40 was only for rusty bolts. [Re: therocks] #1584871
02/27/14 12:09 PM
02/27/14 12:09 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I learned the "Water Displacement" qualities when I was a young one.
When it would rain, water would drip down from the cowl area onto the distributor of the smallblock in my dart. I would get a few miles down the road, and it would quit. Best I can figure is the water would evaporate, then condense on the contacts. Popped the cap, gave a spray of WD, and it fired right up.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: And you thought WD40 was only for rusty bolts. [Re: therocks] #1584872
02/27/14 12:10 PM
02/27/14 12:10 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Yep, it's good for anything except removing rust.
Re: And you thought WD40 was only for rusty bolts. [Re: drew72] #1584873
02/27/14 12:44 PM
02/27/14 12:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Must be why Chapper still has swollen rusty nuts.
Re: And you thought WD40 was only for rusty bolts. [Re: dartman366] #1584874
02/27/14 12:47 PM
02/27/14 12:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use it in the construction industry to cold start diesal engines instead of starting either since there is less damage and chance of lock-up.
Re: And you thought WD40 was only for rusty bolts. [Re: B G Racing] #1584875
02/27/14 12:52 PM
02/27/14 12:52 PM
PA.
"Little"John
"Little"John
PA.
You gotta laugh when you see guys spray it on and grab a wrench and start cranking. Its GOOD but not that GOOD.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: And you thought WD40 was only for rusty bolts. [Re: pittsburghracer] #1584876
02/27/14 01:01 PM
02/27/14 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing that works that quick is the good old
blue flame wrench
Re: And you thought WD40 was only for rusty bolts. [Re: OUTLAWD] #1584877
02/27/14 01:23 PM
02/27/14 01:23 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
I was told years ago that WD stood for "Wet Distributor"
Re: And you thought WD40 was only for rusty bolts. [Re: Racer33] #1584878
02/27/14 02:01 PM
02/27/14 02:01 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Re: And you thought WD40 was only for rusty bolts. [Re: tsanchez] #1584879
02/27/14 02:10 PM
02/27/14 02:10 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Also on the starting diesels with it, it doesnt work anymore, at least on vehicles and equipment I have tried it on. Seems they use co2 as a propellant and it used to be LPG.
Re: And you thought WD40 was only for rusty bolts. [Re: tsanchez] #1584880
02/27/14 02:29 PM
02/27/14 02:29 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I've used it to clean air bleeds in race carbs .....it dissolves the dyes in race fuel. Try it and you may pick up a few numbers.
we also use it to treat the junior dragster slicks. We clean with simple green. Then coat with WE 40 and wrap with self clinging wrap. It softens tires and makes them stick.
I now coat my drag car tires with it. My tires no longer get sidewall cracks.
Re: And you thought WD40 was only for rusty bolts. [Re: Chassisman] #1584881
02/27/14 02:52 PM
02/27/14 02:52 PM
PA.
"Little"John
"Little"John
PA.
I'll have to try this on my motorhome tires. Thanks.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: And you thought WD40 was only for rusty bolts. [Re: tsanchez] #1584882
02/27/14 04:33 PM
02/27/14 04:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Temperture here today 19 degrees,just used it to start my Case skidsteer this morning.
Re: And you thought WD40 was only for rusty bolts. [Re: B G Racing] #1584883
02/27/14 06:46 PM
02/27/14 06:46 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
It works great to keep your kids away from what you are working on as well! Spray them once and they go running.
Back in the swing of things at Painless again! Great to be back!
Re: And you thought WD40 was only for rusty bolts. [Re: BJS racing] #1584884
02/27/14 06:57 PM
02/27/14 06:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'll have to try that on my wife when she asked nerdy questions. LOL
But I do love her after 44 years.
Re: And you thought WD40 was only for rusty bolts. [Re: cudaman1969] #1584885
02/27/14 07:20 PM
02/27/14 07:20 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Maybe it will start a diesel but it certainly wont start a gas engine. I cant even get it to light on fire.
67' charger 499 RB 10.57 at 127
Re: And you thought WD40 was only for rusty bolts. [Re: dragram440] #1584886
02/27/14 07:26 PM
02/27/14 07:26 PM
PA.
"Little"John
"Little"John
PA.
Something i will add since I now buy it by the gallon and pour it in plastic spray bottles. Shake the can before using because it does separate. You can really notice it in a clear bottle.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
