I installed a lift in our garage. When I wish to park Challenger on either bunk, the fixed antenna that I now have is too long and I must pull the mast off. Same would apply even for the collapsible antennas. So think that a power antenna that would go way down low would be a good way to go.
Any recommendations on a power antenna might do the job? All those that I have found are only 1/2 inch in diameter where it pokes thru the fender.. My existing hole in fender 1.3 inches in diameter. This is far too much slop to get a good fit. The non- power antenna that I am replacing is about .9 inch where I pokes thru the fender hole. Antenna is mounted on right front fender.
I may be able to fit incorrect power antenna using some washers and stuff that I picked up at local hardware store.
Turns out that very few power antennas are now marketed compared to past. Likely because most newer vehicles use windshield mounted antenna now.
