LF axle wobbles at pumpkin 2004 15500 P/U #1584475
02/26/14 09:30 AM
02/26/14 09:30 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I've seen conflicting info. It needs an a half shaft axle for sure. Stub shaft wear? Stub shaft just pulls out? Diff needs to come apart? Who's done one? I'm assuming it's like the right side. Remove half shaft, pull the stub if it's worn also?
Doug
Re: LF axle wobbles at pumpkin 2004 15500 P/U [Re: dvw] #1584476
02/26/14 09:57 AM
02/26/14 09:57 AM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Stub shaft wear is very a common issue with these trucks. If you google stub shaft wear fix dodge, there are a couple pages of cheap fixes to prevent this when you put the new axle in.
Here is a link: http://www.instructables.com/id/03-04-Dodge-Ram-1500-Dakota-Front-Axle-Stubs-Fix/
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
