Page 9 of 12 1 2 7 8 9 10 11 12
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583641
06/20/14 04:09 PM
06/20/14 04:09 PM
NC
440Jim Offline
440Jim  Offline
NC
Jim, I'll check but it will be next week. The studs were the only thing Ken didn't have in stock but he ordered them this week and they are being sent directly to me from ARP. So once I get them I'll provide measurements.
I was thinking they were special, meaning they were 1/2" in the block and then necked down to 7/16 at the deck for the 440-1 heads, I didn't notice what size they were when looking at it last night.
KB does offer 1/2" head bolts as an option. He even said they offer 1/2" in the block and 7/16" through the head. I just ordered 7/16" as shown on your quality check list. I don't know what to think that he didn't have studs for your 440-1 heads. When I ordered my block in January he pulled head studs for my order. I wonder where they are...
Re: Keith Black Aluminum block ordering experience [Re: Biginchmopar] #1583642
06/20/14 04:15 PM
06/20/14 04:15 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Just for reference my block is a Hemi block and the studs are 1/2" in the block and 7/16" from the deck surface up. They were special made for my application.
I am thinking about this
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583643
06/20/14 04:18 PM
06/20/14 04:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
So the front & rear mains are not cross bolted? I guess I thought all the after market blocks were cross bolted on all five mains....
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583644
06/20/14 04:42 PM
06/20/14 04:42 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Right where he left them or I guess someone else may have had one on order before us or maybe he's saving them for you..lol
Re: Keith Black Aluminum block ordering experience [Re: Dragula] #1583645
06/20/14 04:48 PM
06/20/14 04:48 PM
Tulsa, Ok
Tulsa, Ok
KB's do not, IndyMAXX blocks do and I think World block do as well. The 3 main caps in the middle of the KB are huge, they stand about 1.5" beyond the oil pan rail where others are even with the oil pan rail.
My Mega block only has cross bolts on 2, 3 and 4 mains.
The KB water block is rated at 2,500hp, not sure what the others are rated for, maybe it's not necessary or maybe they think the 3 in the middle carry most of the load??
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583646
06/20/14 06:27 PM
06/20/14 06:27 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You will also notice the rear main cap and rear main seal are all one unit on the KB. Way better design if you ask me.
Re: Keith Black Aluminum block ordering experience [Re: Biginchmopar] #1583647
06/20/14 08:27 PM
06/20/14 08:27 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A guy I work with is having the same experience with an LSM billet SBC block. Months overdue. Told him last week it would be ready to pick up in a few days final machining yada yada. Called Friday and the new excuse is the main caps aren't done. How exactly do you do final machining or any other machining for that matter, with no main caps???
He has now had to return sponsor money too.
I don't get the over promise and under deliver business model other than they know their competitors can't deliver any quicker (6-9 months) so they make sure they get a BIG downstroke up front so now you're committed and risk losing your deposit if you cancel to buy someone else's unused block.
I'm really surprised there hasn't been any litigation involved with these deals.
Kevin
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583648
06/20/14 08:51 PM
06/20/14 08:51 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Hello , on this photo the webbing is machined off ( drivers side ) at the back of the block . Is there a specific reason for this ? Gary
Re: Keith Black Aluminum block ordering experience [Re: Gabby63] #1583649
06/20/14 10:00 PM
06/20/14 10:00 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
starter clearance
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583650
06/21/14 12:23 PM
06/21/14 12:23 PM
NC
440Jim Offline
440Jim  Offline
NC
KB and I discussed all the head stud options before I ordered my block. I considered the 1/2 to 7/16 studs but decided against it since if you use any other type head (Indy, Edelbrock, B1, etc.) they all use different studs and you would have to buy special studs for the head change. I don't know if all the hemi heads use the same length studs.
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583651
06/24/14 11:55 AM
06/24/14 11:55 AM
Tulsa, Ok
Tulsa, Ok
I thought I'd share a pictures of a few unique things on the KB block
First is a picture of the 2 ARP stainless steel screw in tranny dowel pins. When I first opened the package of block hardware I didn't have a clue what they were for but I did notice the heli-coiled holes on the bell housing flange but I didn't put the them together untill this weekend. I thought this was very nice.
The other item in this picture is the black screw in oil restriction plugs, I think they may be Moroso. They have a hole on the end that goes into the lifter oil galley and then there is also a .060 hole in the tube between the o-ring seal and the treaded end. This will screw into the 2 back lifter oil galley passages. I'm not sure yet if it scews in and seals up at the black flange or if it screw in far enough that a standard NPT plug goes in behind it and actually seals up the oil galley.
Just thought these were pretty cool and thought you guys would like to see these as well.
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583652
06/24/14 02:41 PM
06/24/14 02:41 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
I just got a nice call from Ken Black about 10 minutes ago. He had a quick question about something on my block. He also said that my block should be done Friday.
Greg
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583653
06/25/14 03:22 PM
06/25/14 03:22 PM
NC
440Jim Offline
440Jim  Offline
NC
Good to see your order is almost done.
It looks like your delivery will jump ahead of my order.
I talked to KB on Friday, and he didn't have the casting... and said he will let me know. But no word as of today.
Have you paid the 2nd half of your total?
What heads are you going to use?
if 440-1, see my question about head stud dimensions, when you get yours.
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583654
06/25/14 03:39 PM
06/25/14 03:39 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
if 440-1, see my question about head stud dimensions.
What the heck is still going on with your casting? How many castings has he found bad?
I'm using Original B1's. I'll be using 1/2" studs.
Greg
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583655
06/25/14 03:48 PM
06/25/14 03:48 PM
NC
440Jim Offline
440Jim  Offline
NC
Wade,
Good info on the oil restrictors with O-ring seal. Did you happen to notice if your block is tapped for 7/16 or 1/2 head studs? I realize you are waiting for studs dropped shipped from ARP.
Greg, are your B1 heads already drilled out for 1/2 studs?
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583656
06/25/14 03:59 PM
06/25/14 03:59 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Nope that's not me. I haven't received mine yet.
KB told me maybe Friday it would get done.
Greg
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583657
07/01/14 12:18 PM
07/01/14 12:18 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Well Friday(6/27/14) has come and gone.
No call from KB. My block still must not done yet.
Greg
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583658
07/01/14 02:13 PM
07/01/14 02:13 PM
NC
440Jim Offline
440Jim  Offline
NC
I talked to KB today, 7/1.
He has the casting.
He said they are finishing machining for Greg Knight right now and they will start the 1st and 2nd machining operations on mine after that, hopefully Thursday.
Then he sends it out for gun drilling for hydraulic (lifter bore, pushrod oiling), about Friday. Lastly it comes back for final machining.
I asked him to verify he has the head studs for my order, and the MLS head gaskets. He said he will call me at the end of the week (Thurs or Friday?). He mentioned that the 7/16" studs I ordered have not been a problem getting, but sometimes the 1/2" studs take longer.
When I asked a little more detail about the lifter bore/pushrod oiling mod, he mentioned Wade's block and the Moroso oil restrictors (which I liked).
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583659
07/01/14 03:10 PM
07/01/14 03:10 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
He has the casting.
Thank you.
At least I'm hearing updates from someone
Does he send out the restrictors with all the blocks with pushrod oiling?
Greg
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583660
07/01/14 04:57 PM
07/01/14 04:57 PM
Tulsa, Ok
Tulsa, Ok
I don't think so, as I had to pay extra for them, not much like $30 or something. So I think you need to ask for them because I think they also need to thread the oil galley so they can be used, so there is some additional machine work. That's what I "think". I do know that I brought this up to him in our discussion when I asked him to gun drill the lifter oil galley, that's when he said he would look into how they could restrict the oil to the galley and get back to me and this is what he came up with, but I would suspect they have done this before.
