Re: Brake conversions
[Re: HotRodRailroader]
#1583464
02/24/14 05:47 PM
02/24/14 05:47 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Personally I like to use factory parts,that way the parts store usually has pads and rotors if I need them. My RR has 73-76 stuff and my 67 has them from an 87.
who is that guy?
#1583465
02/24/14 05:52 PM
02/24/14 05:52 PM
RapidRobert
I believe the 73-76 A disc spindles will fit. & with some 11&3/4" slider adapters/rotors/ceramic pads/bed in procedure you'd have a cheap adequate setup (15" wheels required with 11&3/4). The aftermarket swaps might be lighter & for sure more $$$.
