Looking for wire harness parts...where to buy? #1582841
02/23/14 05:24 PM
02/23/14 05:24 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I would like to get the original temp and oil pressure gauges hooked up in my cuda. Problem is I don't have the connectors for the ends of the wires to connect to the pole on the sending units. They are the rubber covered 90deg ends that slide down onto the pole on the senders. Does anyone know where I can get these without buying a completely new harness?
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: Looking for wire harness parts...where to buy? [Re: tywebb2] #1582842
02/23/14 11:35 PM
02/23/14 11:35 PM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
http://www.wiringharness.com/
Try M & H at the above web site.
Re: Looking for wire harness parts...where to buy? [Re: tywebb2] #1582843
02/24/14 02:47 AM
02/24/14 02:47 AM
scratchnfotraction Offline
I have a box of wireharness just for clipping ends and splice out of them.
you want a stud push on 90* end that is most times orange color wire(what my truck always have)
and the same stud push on 90* end for a oil sender that most times is a white wire.
oil sender also use a stud with flat tip and slide on spade connector with white wire also.
double check this one...?
I have both if IIRC.
Re: Looking for wire harness parts...where to buy? [Re: scratchnfotraction] #1582844
02/24/14 11:23 PM
02/24/14 11:23 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Yes you are right...the oil pressure sender has a round flat top that a spade connector slides onto. What did this factory connector look like? Any different than a normal spade connector?
'72 440 Cuda
