Hog Ring Plier Recommendations
#1582588
02/22/14 10:47 PM
02/22/14 10:47 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I am going to be in the process of recovering my rear bench seat soon and I need to purchase a semi-decent set of hog ring pliers to do this. I have a set of Legendary covers on order and have the seats torn down. I was very careful tearing them down and took a bunch pictures to help me remember how they go together. Can anybody here recommend a set of pliers? I see Eastwood has their brand but I see kinda cruddy reviews on them. Anybody here have a good set they can recommend I purchase? This may seem kind of elementary to some but I see a ton of different types of these pliers and sizes of these rings. On a related note, I have the "netting" that goes between the foam and the steel frame and it has these thin rusty wires woven through it. How would I go about cleaning that up without destroying the netting?
Re: Hog Ring Plier Recommendations
[Re: cjskotni]
#1582589
02/22/14 11:17 PM
02/22/14 11:17 PM
moparpollack
Lil Herman
Lil Herman
85086
The hog ring pliers I used were from tractor supply. One thing I did was mark were the factory put the rings. Additionally Home Depot sells really small clamps for like 37 cents they are good at holding material in place before you put on your hog rings. Good luck!
[Re: cjskotni]
#1582590
02/22/14 11:20 PM
02/22/14 11:20 PM
Posts: 1,286 IN
GTX4spd
IN
Well, we used to raise hogs so I had a couple of sets of 'em setting around when I did upholstery replacement. Just ones we had bought at the local farm supply store. Don't know what they cost these days but I'd almost bet they're cheaper than the ones an automotive supply prices 'em at. We also had plenty of rings leftover so I used them as well, no different than the automotive rings.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
[Re: cjskotni]
#1582592
02/23/14 12:07 AM
02/23/14 12:07 AM
Challenger 1
Cincinnati, Ohio
I bought these from a place in town called Miami Products or something like that. Local upholstery supply. The pliers are spring loaded and hold the rings nicely, straight head and a angle one. But the best tool I got was the cutters, they cut rings in the tightest areas, wonderfully. Way better than side cutters. I would think Eastwood would be the best place to buy a set if you don't have place local that sells that kind of stuff. Do you really use hog rings on hogs?
[Re: Challenger 1]
#1582594
02/23/14 12:41 AM
02/23/14 12:41 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I'm a city boy so I don't know firsthand, but my understanding is that hog rings are clamped into pig's noses to keep them from rooting around in the garden at farms. The first set of seats I did I used the set on the right in my picture, and it was no fun. A couple years back I bought another set of seat covers from Legendary and decided I'd treat myself to a new set of hog ring pliers for installing this set. I found one on ebay for around $20 complete with some hog rings. Spring loaded, padded handles, worked great! Even made in the USA. Mine were made by Republic Fastener Products Corporation. http://www.ebay.com/itm/Hog-rings-and-pl...=item23355e3ee3
[Re: Mastershake340]
#1582595
02/23/14 01:23 AM
02/23/14 01:23 AM
Posts: 1,286 IN
GTX4spd
IN
Yep, you really use rings on hogs, precisely to keep them from destroying the turf & keep them from rooting up the bottom of fences. Some hogs needed a whole snoutfull to stop 'em, some were never deterred no matter how many rings you put in 'em, & some were quite adept at pulling the rings out. You don't know what fun is until you have to snare & hold a screaming, wiggling hog while someone clamps the rings in, or vice-versa. And if it's young pigs with sows nearby you take your life in your hands, a sow is every bit as protective of any screaming pig as a mother bear (also called sow) is of it's cubs.
[Re: GTX4spd]
#1582596
02/23/14 09:22 AM
02/23/14 09:22 AM
Challenger 1
Cincinnati, Ohio
Thanks, I really didn't know for sure.
Wonder if they would work on my dog? Can you use them on dogs?
[Re: Challenger 1]
#1582599
02/23/14 11:29 AM
02/23/14 11:29 AM
cjskotni
North Carolina
Give the whole thing a light glass beading and then a coat of spray paint.
So just spray the entire netting? I had thought of that but I was hoping there was a way to keep it looking original (not that you will ever see it).
Thanks for the suggestion!
