Re: Modern Type Master Cylinder?
[Re: Jax.Jags]
#1582406
02/22/14 03:39 PM
02/22/14 03:39 PM
RapidRobert
Alright, The later alum/plastic M/C has no advantage (that I am aware of) other than a slight weight saving & it could possibly be had in a bore size closer to exactly what you need for your desired pedal effort but I think the iron one can be had in a basic disc/drum size that will work fine for you. I'd get/install one for a disc/drum app & it'll be fine for your later disc swap.
[Re: Jax.Jags]
#1582409
02/23/14 02:19 PM
02/23/14 02:19 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
As cheap as a reman master is along with wheel cylinders,I would just go to Advance Auto Parts and get what you need in the stock stuff.When you upgrade to discs later,then change over as a complete deal and use silicone (DOT 5) brake fluid.You can also get a coupon on line and order over on AAP's site for more savings. And when you get it driveable,bring it up to the Hardee's on Merrill Rd, there is a cruise in there every 1st weekend of every month.
[Re: Jax.Jags]
#1582410
02/23/14 09:46 PM
02/23/14 09:46 PM
Posts: 43,298 Bend,OR USA
Cab_Burge
I should've been a bit more specific...by modern I meant the late model aluminum/plastic type mopar MC that can be mounted with an adapter, or possibly something like a Red Bore offered by Just suspension. Eventually I'll upgrade to front discs but the priority is just to get it driving safely until then. I just am trying to avoid spending money twice or three times. It's never going to be a pro-touring caliber ride, but a nice resto-mod. So, if I can get something now that would give me better performance and a little room to upgrade; well that's what I'm really asking...thanks to all...
All the drum brake master cylinders have residual valves in both lines, OEM disc brake master cylinders do not have them for the disc brakes Drum brakes need around 10 lbs of residual pressure on them to kieep the linings from retracting to far away from the drums when the brakes are not appiled, disc braes do not need them or the residual pressure
