Re: KB engine build
[Re: supercomp]
#1581992
02/22/14 08:56 AM
02/22/14 08:56 AM
Posts: 2,924 A shed in England
Tig
A shed in England
You will be ahead of the game with a raised cam block if you're going to go 604 with a wedge head. With a standard spaced cam tunnel, you can't get any decent lift without fouling the rods with a 4.75 arm. Lift can be addressed by rocker arm ratio but that creates there own little problems. Better off deciding now, belt drive is a lot more expensive than non raised cam tunnel. We've not ran bushed lifter bores and they're holding up fine. Our's is 580ci btw. Nice reliable, low maintenance 850 ish HP. 6700 shift. 7200 max rpm. see sig. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
