I have to start getting going again on my Charger, the car has very little rust, has original floors, and quarters, had to put a trunk floor in it due to rust in the rear window channel, and now I need to repair a rust spot where battery acid corroded the inner fender around the tray mounting area.
The rust area is a small area, but runs the compound angle area where the tray bolts to, and where the access hole below is, I have decided to buy a whole inner fender, cut the 10" or so patch out of it and weld it in. Is there going to be any difference in quality of getting a 100 dollar one to use for this graphing? you can buy the goodmark on ebay for 120.00 shipped, and am thinking this is the way to go, just don't want get it and realize its junk.
Duane
