Are these 73-76 abody disc brakes? #1581483
02/20/14 12:15 AM
02/20/14 12:15 AM
CT,USA
72CUDA340 Offline OP
CT,USA
These where in a pile of parts that came with my 72 cuda when I bought it. Do I have to pull the rotors off to find casting numbers on the spindles? The discs are 11 3/4" and bolt patter is 5x4.5. Is this an a body setup?
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581484
02/20/14 12:18 AM
02/20/14 12:18 AM
BDW Online content
BDW  Online Content
Take some measurements
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581485
02/20/14 12:25 AM
02/20/14 12:25 AM
CT,USA
CT,USA
another pic
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581486
02/20/14 12:29 AM
02/20/14 12:29 AM
AndyF Offline
AndyF  Offline
Looks like B-body but could be C-body. A-body never came with 11.75 rotors nor did they ever have a lower ball joint like that.
Width of the rotor will tell you if it is B or C. Or pull the rotors off and look at the wheel bearings. The B body knuckles fit on ABE cars but you'll need to change the calipers.
Re: Are these 73-76 abody disc brakes? [Re: AndyF] #1581487
02/20/14 12:52 AM
02/20/14 12:52 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Cordoba set up? Not e-body also because steering arm holds the ball joint pin not the ball joint itself. Unless it has been cut off?
I made this if it helps?
Re: Are these 73-76 abody disc brakes? [Re: brads70] #1581488
02/20/14 01:23 AM
02/20/14 01:23 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Isn't '72 the last year for "pin" calipers on B & E-bodies. What did the c-bodies use?
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581489
02/20/14 01:41 AM
02/20/14 01:41 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Those are mid '70s B-body 10.95" brakes.
Re: Are these 73-76 abody disc brakes? [Re: DoctorDiff] #1581490
02/20/14 02:22 AM
02/20/14 02:22 AM
CT,USA
CT,USA
Thanks guys, So I take it none of these parts would work on a 1972 cuda,except for maybe the splash shields? I also have a 1968 road runner would any of this stuff work on that?
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581491
02/20/14 04:02 AM
02/20/14 04:02 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They will work on both cars with the correct lower ball joint for those cars...
Re: Are these 73-76 abody disc brakes? [Re: 72CUDA340] #1581492
02/20/14 04:07 AM
02/20/14 04:07 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The brakes will fit your Barracuda and Road Runner. You just re-use your original lower ball joints.
Re: Are these 73-76 abody disc brakes? [Re: DoctorDiff] #1581493
02/20/14 03:27 PM
02/20/14 03:27 PM
AndyF Offline
AndyF  Offline
Those calipers aren't the best choice to use. But they look like cores anyway so just swap them for some late model FMJ calipers which are designed to be rear hung and you should be set.
Re: Are these 73-76 abody disc brakes? [Re: AndyF] #1581494
02/21/14 01:51 PM
02/21/14 01:51 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
To change those pin style calipers to the late model FMJ rear hung calipers, you will need to change the caliper adapter that bolts to the spindle, and get the slider calipers for the FMJ . . .
