Re: 727 losing fluid from rear vent
[Re: J_BODY]
#1581118
02/19/14 01:27 PM
02/19/14 01:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know why yours would be puking fluid unless its over full... I have my vent mounted in the rear (727, TA brake front vent plugged) and never had a drop come out... the can and hose might be the only thing for your... I just dont know why its dripping
[Re: MoParFish]
#1581119
02/19/14 01:27 PM
02/19/14 01:27 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Run a little less fluid?? We do it in the glides all the time. About a pint low. Or a puke tank which we are required to run anyway.
[Re: Al_Alguire]
#1581120
02/19/14 05:02 PM
02/19/14 05:02 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Whats the total qts you put in using a deep pan
[Re: mokid]
#1581121
02/19/14 05:58 PM
02/19/14 05:58 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Depends on the size of the converter. Usually 8 quarts.
[Re: Sammy]
#1581122
02/19/14 08:02 PM
02/19/14 08:02 PM
mokid
St.Louis, Mo.
That seems like alot Usually 8 quarts.
[Re: J_BODY]
#1581128
02/21/14 04:53 AM
02/21/14 04:53 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I run mine to the oem 1 pint low mark. I can see your point, that what used to work, now doesn't. I've followed these types of threads for years, and nothing cause related has surfaced. As you know, that area of the trans is totally open, and away from the pressurized oil. At least it is, if the gov support is plugged (yours is), and the sealing rings are on the right land (again yours is). Good luck.
