Duster? #1581071
02/19/14 01:28 AM
02/19/14 01:28 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Working on a 72 Duster and I need a fender. Found a 73 with good fenders, will they interchange?
Re: Duster? [Re: dart4forte] #1581072
02/19/14 02:59 AM
02/19/14 02:59 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, 72 is unique due to the early (1967-72) head light shape and the newer (1972-1976) marker light style hole
Re: Duster? [Re: ScottSmith_Harms] #1581073
02/19/14 03:12 AM
02/19/14 03:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 73 fender fits fine. You would need to make a small tab to connect to the steel panel that supports the grille.
The side marker lens is the same.
Re: Duster? [Re: Kern Dog] #1581074
02/19/14 03:54 AM
02/19/14 03:54 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, that's the difference, but if I were given the choice I'd turn a 70-71 fender into a 72 by patching and re cutting the marker hole before adding metal to make the lower panel.
Either way, if you want a direct, no modification bolt on part, the 1972 is on it's own.
Re: Duster? [Re: ScottSmith_Harms] #1581075
02/19/14 04:42 AM
02/19/14 04:42 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
John, 72 Scamp is the same as 72 Duster...
I am truckless..
Re: Duster? [Re: 340SHORTY] #1581076
02/19/14 05:59 PM
02/19/14 05:59 PM
Mesa, Arizona
Mesa, Arizona
Have a pair of 73's that are almost perfect. Shame they can't be used.
Re: Duster? [Re: dart4forte] #1581077
02/19/14 07:58 PM
02/19/14 07:58 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
You CAN use the 73 fenders, it just takes a little fabrication to do it.
If I remember, the 73-76 fenders used a small piece below the grille that was held in by (2) phillips head screws that mated up to the different style lower grille panel.
Take those off (if they're on the fender), & the lower holes will be in the same place as on your 72 fenders.
You'll need to make, or take the brackets off of your fenders that hold the upper grille panel to the fender.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: Duster? [Re: dart4forte] #1581078
02/20/14 12:58 PM
02/20/14 12:58 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
what side??
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
