'70 Coronet 318 conversion to non-AC #1581035
02/19/14 12:03 AM
02/19/14 12:03 AM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
On a '70 Coronet, I'm removing the A/C from the 318. It has a Saginaw pump. It doesn't need to be factory correct, but it does need to work for daily driving. Does anybody have a picture of this arrangement?
With two Mopar swap meets coming up, I'd like to pick up the necessary pulley(s) and alternator brackets (if required).
It currently has a 3-groove crank pulley. Two rear grooves for A/C & alt. The front groove for the WP & PS is ~1/2" smaller in diameter.
Thanks for your help.
Re: '70 Coronet 318 conversion to non-AC [Re: 68red440] #1581036
02/19/14 02:03 AM
02/19/14 02:03 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Sent you a PM
Re: '70 Coronet 318 conversion to non-AC [Re: 68red440] #1581037
02/22/14 10:40 AM
02/22/14 10:40 AM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
Anybody know the correct belt routing and pulleys? Pictures would be helpful for a Saginaw pump, non-AC 318. Thx
