turbo carbon seal.HELP! #1580877
02/18/14 05:46 PM
02/18/14 05:46 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am working on a project for a draw thru carb TT and I can not find info on who puts in the carbon seal and how big of a turbo it can be put in.[GT4088]
This is just a CAD I did to keep track of the build and measurements.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580878
02/18/14 09:03 PM
02/18/14 09:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Call tech at Precision Turbo. If anyone can help they can.
Re: turbo carbon seal.HELP! [Re: FastmOp] #1580879
02/18/14 09:30 PM
02/18/14 09:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got an e mail from PT saying that there is no carbon seal turbo offered or installed!
Re: turbo carbon seal.HELP! [Re: Clanton] #1580880
02/18/14 11:28 PM
02/18/14 11:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
quickD100 is trying with some success to blow up a 318 with a draw thru system.
https://board.moparts.org/ubbthreads/show...rue#Post8039781
He might have some info on the seal you need and where to get it. He is running a GT45 single.
Kevin
Re: turbo carbon seal.HELP! [Re: Twostick] #1580881
02/19/14 12:03 AM
02/19/14 12:03 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
no actualy It is TT maybe some GT4088's but I am looking for what will work with size,brand.I will see if I can PM him,Thx!
Re: turbo carbon seal.HELP! [Re: Clanton] #1580882
02/19/14 08:33 AM
02/19/14 08:33 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I hesitate to tell you because you would be much better off not going draw thru, but turbonetics still does ceramic/carbon seals for draw thru. The boat guys still do this for some reason, and turbonetics still caters to them. I dont think you will get any GT series turbos with these seals, but efficientcy doesn't seem to be high on the priorities of this build anyway. There are still alot of good turbos out there in non-GT variety, and they are much cheaper.
Re: turbo carbon seal.HELP! [Re: TRENDZ] #1580883
02/19/14 11:05 AM
02/19/14 11:05 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Just wondering why you would go draw through instead of blowthru? Not being critical just wondering
Re: turbo carbon seal.HELP! [Re: TRENDZ] #1580884
02/19/14 12:18 PM
02/19/14 12:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks TRENDZ for the lead and I will give them a call.I just gave the GT4088 as a Idea on size I may want.The draw thru is just what I want weather good,bad.I can't drive my car like it is on the street and I am looking at that more all the time.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580885
02/19/14 12:25 PM
02/19/14 12:25 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Why not?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: turbo carbon seal.HELP! [Re: an8sec70cuda] #1580886
02/19/14 01:42 PM
02/19/14 01:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The obstruction sticking out of the hood!Laws against it.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580887
02/19/14 02:30 PM
02/19/14 02:30 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
When you take that obstruction off, let me know, I'll take it to the junk yard for you.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580888
02/19/14 02:40 PM
02/19/14 02:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I just talked to turbonetics and the largest turbo I can get is a to4E 60 for 800hp max falling short of my 1,000 to 1200 hp goal.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580889
02/19/14 03:58 PM
02/19/14 03:58 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Switch to blowthru and problem solved
Re: turbo carbon seal.HELP! [Re: SLOW67] #1580890
02/19/14 04:45 PM
02/19/14 04:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want a draw thru simple as that!
Re: turbo carbon seal.HELP! [Re: Clanton] #1580891
02/19/14 05:25 PM
02/19/14 05:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Get two turbos for a hot air turbo Buick. 1981 were hot air cars. I think some of the late 70's trans AMs were hot air as well.
You want to make big power but will never make it with your approach.
You could do a single 88 and blow thru and accomplish your goals.
You know how to make headers now and you ain't scared to spend the $$. I would think you would want the HP without the hassle.
Re: turbo carbon seal.HELP! [Re: FastmOp] #1580892
02/19/14 05:35 PM
02/19/14 05:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i don't have to make big power but ya gotta start somewhere.You must understand that my goal is for a draw thru not a blow thru good bad or other I am finding what the limits are and go from there.
Re: turbo carbon seal.HELP! [Re: Clanton] #1580893
02/19/14 07:29 PM
02/19/14 07:29 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Might try a Aussie forum or something like that,I think some of those guys might still run draw through. Not to sound like an a** but why do something the hard way when you can get better results easier? A big single/blowthru would do the job, be lighter, easier to plumb, way easier to tune etc. Just trying to wrap my head around the why part.
Re: turbo carbon seal.HELP! [Re: SLOW67] #1580894
02/19/14 07:56 PM
02/19/14 07:56 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I guess a Chevrolet guy might ask the same thing,Why a MOPAR?
Re: turbo carbon seal.HELP! [Re: Clanton] #1580895
02/20/14 02:16 AM
02/20/14 02:16 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
To each his own...good luck with it
Re: turbo carbon seal.HELP! [Re: Clanton] #1580896
02/20/14 02:22 AM
02/20/14 02:22 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You are obviously set on a draw thru. Just get the biggest offerings and live with what you end up with. Looks seem more important than function here anyway. If you like the look of a draw thru system, then you need to be prepared for all the down sides that go with it. The less than stellar all out performance goes hand in hand with very poor cold start, laggy spool up, poor cyl to cyl distribution, detonation, explosive boost tubes, etc...
I've gone this route, and believe me, it aint worth the hassle if power is what you're after. For cruise nights or whatever it looks kinda cool, but than you have to come up with a long list of excuses to tell the guys that want to race you.
