Trans mount bolt support plates #1580763
02/18/14 12:54 PM
02/18/14 12:54 PM
Halifax, Nova Scotia
Larry Offline OP
Larry  Offline OP
Does anyone have a picture/diagram/explanation of where the two transmission mount support plates(approx 1 inch by 1.8 inches)are positioned in a 70 - 74 E body (or 71 - 74 B body for that matter). My crossmember came out of an automatic (I am changing to a four speed),and I don't see a defined mark on either side of the mount that would steer me in the right direction. Where they in all applications, 4 speed and automatic? Thanks
Re: Trans mount bolt support plates [Re: Larry] #1580764
02/18/14 05:48 PM
02/18/14 05:48 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Mine are between the trans and the mount
NS1AAR
Re: Trans mount bolt support plates [Re: ns1aar] #1580765
02/18/14 06:07 PM
02/18/14 06:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've got mine on each attaching bolt....like an additional washer. I assumed they were there since the mount has slotted holes.
Re: Trans mount bolt support plates [Re: ns1aar] #1580766
02/18/14 06:08 PM
02/18/14 06:08 PM
Larry Offline OP
Larry  Offline OP
Thanks for that.
Re: Trans mount bolt support plates [Re: burdar] #1580767
02/18/14 06:15 PM
02/18/14 06:15 PM
Larry Offline OP
Larry  Offline OP
That gives us two sets in two different spots, if I am not mistaken. If they are there in an automatic application as well, it almost looked like mine might have been in between, but I can't see any real clear marks left behind.
Re: Trans mount bolt support plates [Re: Larry] #1580768
02/18/14 07:15 PM
02/18/14 07:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
goes on the bolt , then the bolt goes thru the mount
